[postgis-users] Solution of: Cannot compile postgis on Fedora Core 4
Darren Houston dhouston at beyondcompliance.ca
Mon Aug 15 15:25:27 PDT 2005
Hi Marco,
If you don't want to install PostgreSQL from source and want to use the
default PostgreSQL RPM;
Download the PostgreSQL source (same version as installed RPM), configure for
an installation in something like /usr/local/postgis, make but DON'T make
install. make and make install PostGIS from the PostgreSQL source contrib
directory, update the libraries, load the SQL from PostGIS and everything
should work. That's how I do it with Gentoo and the emerged PostgreSQL.
Darren H.
On August 15, 2005 04:04 pm, M. Fioretti wrote:
> On Mon, Aug 15, 2005 15:15:30 PM -0500, Jaime Carrera
> (jaicarrerahdez at yahoo.com) wrote:
> > Hi,
> > I had the same problem and solved it by installing postgresql FROM
> > source (i.e. compiling it).
> > I had this problem in Red Hat 9 and when I upgraded to fedora,
> > decided to compile postgres from source instead of downloading the
> > rpms.
> Yes, I can confirm now that even on Fedora Core 4 you have to do the
> same thing to compile postgis without errors:
> download postgresql sources
> compile and install them
> go to contrib directory in postgresql sources
> compile there as explained on www.postgis.org
> I haven't *tried* it yet, but it did make and make install where I
> wanted without reporting any errors.
> Too bad it doesn't work with standard RPMs. I hope to have time some
> day to figure out how to patch the configure/Makefile of postgis to
> make it work there. Or is it something more serious than a simple
> difference in paths??
> Thanks to all who answered,
>        Marco
