[postgis-users] GTK/Gnome GIS Client
John Cole
john.cole at uai.com
Wed Aug 17 06:54:58 PDT 2005
You might want to try http://sourceforge.net/projects/shapedotnet for a
speed comparison. I've found it performs on par with ESRI's MapObjects. I
ported this to the .Net compact framework, and it was half the speed of
ESRI's ArcPad (both of which were painfully slow).
So not only is there a difference between how you code, you can have a major
difference depending on which CLR you use. I would expect a major
improvement with .Net 2.0 CF, but I haven't played with that yet.
John Cole
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mateusz
Loskot
Sent: Tuesday, August 16, 2005 7:49 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] GTK/Gnome GIS Client
Paul Ramsey napisał(a):
> This is getting extremely OT but:
> Our uDig experience is that it's not the language it's the
> implementation. There's lots of stupid inefficient ways to render
> stuff, and only a few efficient smart ways. If you pick a stupid way,
> you language means nada. Anyhow, doing things the smart way our Java
> implementation seems to run as fast as ESRI's C++ implementation, so
> there you go (for whatever that is worth, which is little).
Yes you are certainly right.
I'm just asking about experiences the Author has witn mono.
In my opinion .NET applications aren't very robust
(weak memory management, you are not able to force GC to destroy
objects, etc.) but it is a matter of taste.
Of cource you don't have to allocate huge structures and collections
in memory as Manifold does, but read all data straight from file
as ArcView.
I have experience with GIS applications on Windows CE mostly, where
resocerces are very limited.
On desktop you may install 3 GHz CPU and TB of RAM,
but when you have 200MHz and 64 MB RAM on Pocket PC device
then you have not many choices.
Mobile GIS apps in .NET are extremly slow, that's what I experienced
and that's why I'm asking.
Definitely, I'm not going to return this thread to technology war :-)
Cheers
Mateusz Łoskot, mateusz (at) loskot (dot) net
Registered Linux User #220771
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
