[postgis-users] PolygonFromText
Nicolas Ribot
nicky666 at gmail.com
Mon Aug 22 07:20:27 PDT 2005
Hi Ahmet,
What do you mean exactly by "an example containing usage" ?
this query generates a triangle polygon from its textual representation:
select polygonfromtext('POLYGON((0 0, 1 0, 1 1, 0 0))', -1);
Note the 2 parenthesis enclosing polygon coordinates (shell and holes
are separated by parenthesis in a polygon)
The last point must be the same as the first one.
-1 is the polygon's SRID. -1 means "no SRID" for Postgis.
Hope this helps
Nicolas
On 8/22/05, orkun <temiz at deprem.gov.tr> wrote:
> hello
> I need to see an example containing usage
> of "PolygonFromText".
> I will appreciate if anyone sends it.
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
> postgis-users mailing list
