[postgis-users] cannot enter password to load shp
RIBOT, Nicolas
nicolas.ribot at astrium.eads.net
Mon Mar 14 07:08:24 PST 2005
> I'm trying to load shapefiles into postgis in the DOS command > window and
with the interface "s2pface". When running shp2pgsql I am requested to enter
a password on the DOS prompt, > but I cannot write anything on the command
line. I'm using XP > Pro and am not sure if it has to do with XP or anything
else.
> Did anybody have the same experience. I would appreciate any > useful
tips, even if my question may not be directly related > to postgis.
Hello,
S2pface does not include a box to enter the postgresql password.
2 options then: either set your postgresql access to "trust" (in the
pg_hba.conf file) and you wont need to enter a password,
or (better) use shp2pgsql in command line. It is pretty straightforward.
Typing shp2pgsql in a command windows will show you the command line help.
(sp2face is just a GUI to shp2pgsql)
Nicolas
CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
