[postgis-users] What are people using to load gps data? [SEC=UNCLASSIFIED]
Roppola, Antti - BRS Antti.Roppola at brs.gov.au
Sun May 13 18:20:56 PDT 2007
Matthew Perry wrote:
> gpsbabel -> gpx2shp -> shp2pgsql works great for me. I just wrap it in
> a little shell/bat script so everytime I need to get data off my gps
> into the database, its just a single command.
Does that just do tracks, or does it also maintain attribute data for
each point (date/time, z-value, etc.)?
I was thinking that keeping the points as points and having a line view
would be a neat way of presenting tidy lines and keeping attribute data.
Antti
------IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
