[postgis-users] PostGIS on PostgreSQL < 8.0
Håvard Tveite havard.tveite at umb.no
Fri Sep 14 02:36:33 PDT 2007
Paul Ramsey wrote:
> How many folks are using the latest PostGIS on PgSQL < 8.0?
>  From a development point-of-view, the quantity of
> backwards-compatibility code is growing and growing, and that makes the
> code base a lot less pleasant.
> Are there still lots of people using PgSQL < 8.0 with the latest PostGIS?
While I can't point to specific people using pgSQL < 8.0,
I still think it is too early to require PostgreSQL >= 8.
Stability is very important, and there must still be many
organisations using PostgreSQL 7 (and many of them will
most probably not be on the postgis mailing lists...).
If new versions of PostGIS are not going to be pg < 8
compatible, I think it is important that the latest
compatible version is maintained as a stable standards
(SQL/MM Spatial, ...) compliant version (bug fixes to ensure
correct operation of all geometry related operators).
PostGIS as a product is not as mature as PostgreSQL, so I
guess many will currently be interested in upgrading
PostGIS more frequently than PostgreSQL.
Håvard Tveite
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
