[postgis-users] problem installing WKTRaster
Jorge Arévalo
jorge.arevalo at deimos-space.com
Mon Jul 19 02:37:38 PDT 2010
On Mon, Jul 19, 2010 at 11:32 AM, Sebastian E. Ovide
<sebastian.ovide at gmail.com> wrote:
> done, same problem
> ERROR: could not load library "C:/Program
> Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
> found.
Try adding C:/Program Files/PostgreSQL/8.4/lib/ to the PATH enviroment variable.
> 2010/7/19 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> On Mon, Jul 19, 2010 at 11:01 AM, Sebastian E. Ovide
>> > Hi All,
>> > on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
>> > Just followed the instructions from WKTRaster 0.1.6d readme.txt and when
>> > I'm
>> > running the rtpostgis.sql I'm getting this error:
>> > NOTICE: type "raster" is not yet defined
>> > DETAIL: Creating a shell type definition.
>> > be
>> > found.
>> > ********** Error **********
>> > be
>> > found.
>> > SQL state: 58P01
>> > But I do have that file !!!!
>> > C:\Documents and Settings\sebastian ovide>dir "C:\Program
>> > Files\PostgreSQL\8.4\lib\rtpostgis.dll"
>> > Volume in drive C has no label.
>> > Volume Serial Number is 2079-A57D
>> > Directory of C:\Program Files\PostgreSQL\8.4\lib
>> > 21/06/2010 13:52 210,432 rtpostgis.dll
>> > 1 File(s) 210,432 bytes
>> > 0 Dir(s) 450,924,576,768 bytes free
>> > now, If I use the backslash... ( as for the error)
>> > C:\Documents and Settings\sebastian ovide>dir "C:/Program
>> > File Not Found
>> > ideas ?
>> > thanks
>> > Sebastian E. Ovide
>> Hi,
>> Try copying rtpostgis.dll in C:\Program Files\PostgreSQL\8.4\bin directory
>> Best regards,
>> Jorge Arévalo
>> DEIMOS Space
>> Internet & Mobilty Division
>> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
>> 28760 Tres Cantos (Madrid)
>> Tel: +34 91 806 34 50 - ext: 155
>> http://gis4free.wordpress.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Sebastian E. Ovide
Jorge Arévalo
DEIMOS Space
