[postgis-users] problem installing WKTRaster
Sebastian E. Ovide
sebastian.ovide at gmail.com
Mon Jul 19 03:56:20 PDT 2010
same:
ERROR: could not load library "C:/Program
Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
found.
2010/7/19 Jorge Arévalo <jorge.arevalo at deimos-space.com>
> On Mon, Jul 19, 2010 at 11:32 AM, Sebastian E. Ovide
> <sebastian.ovide at gmail.com> wrote:
> > done, same problem
> be
> > found.
> Try adding C:/Program Files/PostgreSQL/8.4/lib/ to the PATH enviroment
> variable.
> >> On Mon, Jul 19, 2010 at 11:01 AM, Sebastian E. Ovide
> >> > Hi All,
> >> > on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
> >> > Just followed the instructions from WKTRaster 0.1.6d readme.txt and
> when
> >> > I'm
> >> > running the rtpostgis.sql I'm getting this error:
> >> > NOTICE: type "raster" is not yet defined
> >> > DETAIL: Creating a shell type definition.
> not
> >> > be
> >> > found.
> >> > ********** Error **********
> not
> >> > be
> >> > found.
> >> > SQL state: 58P01
> >> > But I do have that file !!!!
> >> > C:\Documents and Settings\sebastian ovide>dir "C:\Program
> >> > Files\PostgreSQL\8.4\lib\rtpostgis.dll"
> >> > Volume in drive C has no label.
> >> > Volume Serial Number is 2079-A57D
> >> > Directory of C:\Program Files\PostgreSQL\8.4\lib
> >> > 21/06/2010 13:52 210,432 rtpostgis.dll
> >> > 1 File(s) 210,432 bytes
> >> > 0 Dir(s) 450,924,576,768 bytes free
> >> > now, If I use the backslash... ( as for the error)
> >> > C:\Documents and Settings\sebastian ovide>dir "C:/Program
> >> > File Not Found
> >> > ideas ?
> >> > thanks
> >> > Sebastian E. Ovide
> >> Hi,
> >> Try copying rtpostgis.dll in C:\Program Files\PostgreSQL\8.4\bin
> directory
> >> Best regards,
> >> Jorge Arévalo
> >> DEIMOS Space
> >> Internet & Mobilty Division
> >> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
> >> 28760 Tres Cantos (Madrid)
> >> Tel: +34 91 806 34 50 - ext: 155
> >> http://gis4free.wordpress.com
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Sebastian E. Ovide
> Jorge Arévalo
> DEIMOS Space
Sebastian E. Ovide
skype: sebastian.ovide
+353 (0) 87 6340149
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100719/a77d7785/attachment.html>
