[postgis-users] problem installing WKTRaster
Jorge Arévalo
jorge.arevalo at deimos-space.com
Mon Jul 19 04:01:52 PDT 2010
On Mon, Jul 19, 2010 at 12:56 PM, Sebastian E. Ovide
<sebastian.ovide at gmail.com> wrote:
> same:
> ERROR: could not load library "C:/Program
> Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
> found.
Mmmm... strange. Ensure both directories:
C:/Program Files/PostgreSQL/8.4/lib
C:/Program Files/PostgreSQL/8.4/bin
Are included in PATH enviroment var. And then, open a new console and
try to load rtpostgis.sql from it. You can try it from PgAdmin too...
> 2010/7/19 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> On Mon, Jul 19, 2010 at 11:32 AM, Sebastian E. Ovide
>> > done, same problem
>> > be
>> > found.
>> Try adding C:/Program Files/PostgreSQL/8.4/lib/ to the PATH enviroment
>> variable.
>> >> On Mon, Jul 19, 2010 at 11:01 AM, Sebastian E. Ovide
>> >> > Hi All,
>> >> > on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
>> >> > Just followed the instructions from WKTRaster 0.1.6d readme.txt and
>> >> > when
>> >> > I'm
>> >> > running the rtpostgis.sql I'm getting this error:
>> >> > NOTICE: type "raster" is not yet defined
>> >> > DETAIL: Creating a shell type definition.
>> >> > not
>> >> > be
>> >> > found.
>> >> > ********** Error **********
>> >> > not
>> >> > be
>> >> > found.
>> >> > SQL state: 58P01
>> >> > But I do have that file !!!!
>> >> > C:\Documents and Settings\sebastian ovide>dir "C:\Program
>> >> > Files\PostgreSQL\8.4\lib\rtpostgis.dll"
>> >> > Volume in drive C has no label.
>> >> > Volume Serial Number is 2079-A57D
>> >> > Directory of C:\Program Files\PostgreSQL\8.4\lib
>> >> > 21/06/2010 13:52 210,432 rtpostgis.dll
>> >> > 1 File(s) 210,432 bytes
>> >> > 0 Dir(s) 450,924,576,768 bytes free
>> >> > now, If I use the backslash... ( as for the error)
>> >> > C:\Documents and Settings\sebastian ovide>dir "C:/Program
>> >> > File Not Found
>> >> > ideas ?
>> >> > thanks
>> >> > Sebastian E. Ovide
>> >> Hi,
>> >> Try copying rtpostgis.dll in C:\Program Files\PostgreSQL\8.4\bin
>> >> directory
>> >> Best regards,
>> >> Jorge Arévalo
>> >> DEIMOS Space
>> >> Internet & Mobilty Division
>> >> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
>> >> 28760 Tres Cantos (Madrid)
>> >> Tel: +34 91 806 34 50 - ext: 155
>> >> http://gis4free.wordpress.com
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> > Sebastian E. Ovide
>> Jorge Arévalo
>> DEIMOS Space
> Sebastian E. Ovide
> skype: sebastian.ovide
> +353 (0) 87 6340149
Jorge Arévalo
DEIMOS Space
