[postgis-users] problem installing WKTRaster
Sebastian E. Ovide
sebastian.ovide at gmail.com
Mon Jul 19 04:13:30 PDT 2010
Hi Fred,
Thanks to that Tool I've discovered that the dll could not find
libgdal.dll... so I've copied it into the bin dir and now it works !
thanks !
On Mon, Jul 19, 2010 at 12:03 PM, Fred Lehodey <lehodey at gmail.com> wrote:
> Hi Sebastian,
> you can try that free utility : http://www.dependencywalker.com/
> Sometimes helpful to discover a missing file.
> Fred.
> On Mon, Jul 19, 2010 at 11:56 AM, Sebastian E. Ovide <
> sebastian.ovide at gmail.com> wrote:
>> same:
>> ERROR: could not load library "C:/Program
>> Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
>> found.
>> 2010/7/19 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>>> On Mon, Jul 19, 2010 at 11:32 AM, Sebastian E. Ovide
>>> <sebastian.ovide at gmail.com> wrote:
>>> > done, same problem
>>> be
>>> > found.
>>> Try adding C:/Program Files/PostgreSQL/8.4/lib/ to the PATH enviroment
>>> variable.
>>> >> On Mon, Jul 19, 2010 at 11:01 AM, Sebastian E. Ovide
>>> >> > Hi All,
>>> >> > on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
>>> >> > Just followed the instructions from WKTRaster 0.1.6d readme.txt and
>>> when
>>> >> > I'm
>>> >> > running the rtpostgis.sql I'm getting this error:
>>> >> > NOTICE: type "raster" is not yet defined
>>> >> > DETAIL: Creating a shell type definition.
>>> not
>>> >> > be
>>> >> > found.
>>> >> > ********** Error **********
>>> not
>>> >> > be
>>> >> > found.
>>> >> > SQL state: 58P01
>>> >> > But I do have that file !!!!
>>> >> > C:\Documents and Settings\sebastian ovide>dir "C:\Program
>>> >> > Files\PostgreSQL\8.4\lib\rtpostgis.dll"
>>> >> > Volume in drive C has no label.
>>> >> > Volume Serial Number is 2079-A57D
>>> >> > Directory of C:\Program Files\PostgreSQL\8.4\lib
>>> >> > 21/06/2010 13:52 210,432 rtpostgis.dll
>>> >> > 1 File(s) 210,432 bytes
>>> >> > 0 Dir(s) 450,924,576,768 bytes free
>>> >> > now, If I use the backslash... ( as for the error)
>>> >> > C:\Documents and Settings\sebastian ovide>dir "C:/Program
>>> >> > File Not Found
>>> >> > ideas ?
>>> >> > thanks
>>> >> > Sebastian E. Ovide
>>> >> Hi,
>>> >> Try copying rtpostgis.dll in C:\Program Files\PostgreSQL\8.4\bin
>>> directory
>>> >> Best regards,
>>> >> Jorge Arévalo
>>> >> DEIMOS Space
>>> >> Internet & Mobilty Division
>>> >> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
>>> >> 28760 Tres Cantos (Madrid)
>>> >> Tel: +34 91 806 34 50 - ext: 155
>>> >> http://gis4free.wordpress.com
>>> >> _______________________________________________
>>> >> postgis-users mailing list
>>> >> postgis-users at postgis.refractions.net
>>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> > Sebastian E. Ovide
>>> Jorge Arévalo
>>> DEIMOS Space
>> Sebastian E. Ovide
>> skype: sebastian.ovide
>> +353 (0) 87 6340149
Sebastian E. Ovide
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100719/58f44d26/attachment.html>
