[postgis-users] problem installing WKTRaster
Jorge Arévalo jorge.arevalo at deimos-space.com
Mon Jul 19 05:22:30 PDT 2010
On Mon, Jul 19, 2010 at 1:13 PM, Sebastian E. Ovide
<sebastian.ovide at gmail.com> wrote:
> Hi Fred,
> Thanks to that Tool I've discovered that the dll could not find
> libgdal.dll... so I've copied it into the bin dir and now it works !
> thanks !
> On Mon, Jul 19, 2010 at 12:03 PM, Fred Lehodey <lehodey at gmail.com> wrote:
>> Hi Sebastian,
>> you can try that free utility : http://www.dependencywalker.com/
>> Sometimes helpful to discover a missing file.
>> Fred.
Great tool! Thanks
>> On Mon, Jul 19, 2010 at 11:56 AM, Sebastian E. Ovide
>>> same:
>>> ERROR:  could not load library "C:/Program
>>> Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
>>> found.
>>> 2010/7/19 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>>>> On Mon, Jul 19, 2010 at 11:32 AM, Sebastian E. Ovide
>>>> > done, same problem
>>>> > not be
>>>> > found.
>>>> Try adding C:/Program Files/PostgreSQL/8.4/lib/ to the PATH enviroment
>>>> variable.
>>>> >> On Mon, Jul 19, 2010 at 11:01 AM, Sebastian E. Ovide
>>>> >> > Hi All,
>>>> >> > on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
>>>> >> > Just followed the instructions from WKTRaster 0.1.6d readme.txt and
>>>> >> > when
>>>> >> > I'm
>>>> >> > running the rtpostgis.sql I'm getting this error:
>>>> >> > NOTICE:  type "raster" is not yet defined
>>>> >> > DETAIL:  Creating a shell type definition.
>>>> >> > not
>>>> >> > be
>>>> >> > found.
>>>> >> > ********** Error **********
>>>> >> > not
>>>> >> > be
>>>> >> > found.
>>>> >> > SQL state: 58P01
>>>> >> > But I do have that file !!!!
>>>> >> > C:\Documents and Settings\sebastian ovide>dir "C:\Program
>>>> >> > Files\PostgreSQL\8.4\lib\rtpostgis.dll"
>>>> >> >  Volume in drive C has no label.
>>>> >> >  Volume Serial Number is 2079-A57D
>>>> >> >  Directory of C:\Program Files\PostgreSQL\8.4\lib
>>>> >> > 21/06/2010  13:52           210,432 rtpostgis.dll
>>>> >> >                1 File(s)        210,432 bytes
>>>> >> >                0 Dir(s)  450,924,576,768 bytes free
>>>> >> > now, If I use the backslash... ( as for the error)
>>>> >> > C:\Documents and Settings\sebastian ovide>dir "C:/Program
>>>> >> > File Not Found
>>>> >> > ideas ?
>>>> >> > thanks
>>>> >> > Sebastian E. Ovide
>>>> >> Hi,
>>>> >> Try copying rtpostgis.dll in C:\Program Files\PostgreSQL\8.4\bin
>>>> >> directory
>>>> >> Best regards,
>>>> >> Jorge Arévalo
>>>> >> DEIMOS Space
>>>> >> Internet & Mobilty Division
>>>> >> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
>>>> >> 28760 Tres Cantos (Madrid)
>>>> >> Tel: +34 91 806 34 50 - ext: 155
>>>> >> http://gis4free.wordpress.com
>>>> >> _______________________________________________
>>>> >> postgis-users mailing list
>>>> >> postgis-users at postgis.refractions.net
>>>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> > Sebastian E. Ovide
>>>> Jorge Arévalo
>>>> DEIMOS Space
>>> Sebastian E. Ovide
>>> skype: sebastian.ovide
>>> +353 (0) 87 6340149
> Sebastian E. Ovide
Jorge Arévalo
DEIMOS Space
