[postgis-users] problem installing WKTRaster
Sebastian E. Ovide sebastian.ovide at gmail.com
Mon Jul 19 06:07:52 PDT 2010
Re reading the readme.txt
1) Install PostGIS into your database if you haven't already
2) Copy the rtpostgis.dll to the lib folder of your PostgreSQL install
3)
a) then Run the share\contrib\postgis\rtpostgis.sql in your postgis enabled
db
b) You can install help now too by running
share\contrib\postgis\wktraster_comments.sql
4) Copy the contents of bin to your PostgreSQL bin folder
(gdal2wktraster.py, libgdal.dll) to bin folder of your PostgreSQL install.
the point 4 should come before the point 3....
On Mon, Jul 19, 2010 at 12:13 PM, Sebastian E. Ovide <
sebastian.ovide at gmail.com> wrote:
> Hi Fred,
> Thanks to that Tool I've discovered that the dll could not find
> libgdal.dll... so I've copied it into the bin dir and now it works !
> thanks !
> On Mon, Jul 19, 2010 at 12:03 PM, Fred Lehodey <lehodey at gmail.com> wrote:
>> Hi Sebastian,
>> you can try that free utility : http://www.dependencywalker.com/
>> Sometimes helpful to discover a missing file.
>> Fred.
>> On Mon, Jul 19, 2010 at 11:56 AM, Sebastian E. Ovide <
>>> same:
>>> ERROR:  could not load library "C:/Program
>>> Files/PostgreSQL/8.4/lib/rtpostgis.dll": The specified module could not be
>>> found.
>>> 2010/7/19 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>>>> On Mon, Jul 19, 2010 at 11:32 AM, Sebastian E. Ovide
>>>> <sebastian.ovide at gmail.com> wrote:
>>>> > done, same problem
>>>> not be
>>>> > found.
>>>> Try adding C:/Program Files/PostgreSQL/8.4/lib/ to the PATH enviroment
>>>> variable.
>>>> >> On Mon, Jul 19, 2010 at 11:01 AM, Sebastian E. Ovide
>>>> >> > Hi All,
>>>> >> > on WinXP, with PostgreSLQ 8.4, PostGis 1.5 and WKTRaster 0.1.6d.
>>>> >> > Just followed the instructions from WKTRaster 0.1.6d readme.txt and
>>>> when
>>>> >> > I'm
>>>> >> > running the rtpostgis.sql I'm getting this error:
>>>> >> > NOTICE:  type "raster" is not yet defined
>>>> >> > DETAIL:  Creating a shell type definition.
>>>> not
>>>> >> > be
>>>> >> > found.
>>>> >> > ********** Error **********
>>>> not
>>>> >> > be
>>>> >> > found.
>>>> >> > SQL state: 58P01
>>>> >> > But I do have that file !!!!
>>>> >> > C:\Documents and Settings\sebastian ovide>dir "C:\Program
>>>> >> > Files\PostgreSQL\8.4\lib\rtpostgis.dll"
>>>> >> >  Volume in drive C has no label.
>>>> >> >  Volume Serial Number is 2079-A57D
>>>> >> >  Directory of C:\Program Files\PostgreSQL\8.4\lib
>>>> >> > 21/06/2010  13:52           210,432 rtpostgis.dll
>>>> >> >                1 File(s)        210,432 bytes
>>>> >> >                0 Dir(s)  450,924,576,768 bytes free
>>>> >> > now, If I use the backslash... ( as for the error)
>>>> >> > C:\Documents and Settings\sebastian ovide>dir "C:/Program
>>>> >> > File Not Found
>>>> >> > ideas ?
>>>> >> > thanks
>>>> >> > Sebastian E. Ovide
>>>> >> Hi,
>>>> >> Try copying rtpostgis.dll in C:\Program Files\PostgreSQL\8.4\bin
>>>> directory
>>>> >> Best regards,
>>>> >> Jorge Arévalo
>>>> >> DEIMOS Space
>>>> >> Internet & Mobilty Division
>>>> >> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
>>>> >> 28760 Tres Cantos (Madrid)
>>>> >> Tel: +34 91 806 34 50 - ext: 155
>>>> >> http://gis4free.wordpress.com
>>>> >> _______________________________________________
>>>> >> postgis-users mailing list
>>>> >> postgis-users at postgis.refractions.net
>>>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> > Sebastian E. Ovide
>>>> Jorge Arévalo
>>>> DEIMOS Space
>>> Sebastian E. Ovide
>>> skype: sebastian.ovide
>>> +353 (0) 87 6340149
> Sebastian E. Ovide
Sebastian E. Ovide
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100719/78b5cd7e/attachment.html>
