[postgis-users] gdal2wktraster.py wildchar not working
Jorge Arévalo
jorge.arevalo at deimos-space.com
Thu Jul 22 09:55:49 PDT 2010
On Thu, Jul 22, 2010 at 6:45 PM, Sebastian E. Ovide
<sebastian.ovide at gmail.com> wrote:
> Hi Jorge,
> running the same gdal2wktraster script with those options that have
> suggested have fixed the error...
> i.e:
> sebas at SeansPC:~/rasters$ time ./gdal2wktraster.py -k 512x512 -s 81989 -I -r
> raster/ -t sebastable -o ok.sql
> ./gdal2wktraster.py:727: DeprecationWarning: integer argument expected, got
> float
> hexwkb += wkblify(pt2fmt(pixtype), nodata)
> that means that if the image is too big, "-k is mandatory" (probably it
> should be set with some default...)
> I have to go now.. if it gives any error I'll let you know !
> thanks
Great. So, we only have to focus on the wildcard problem. Keep us
informed if you experiment more problems :-)
Best regards,
Jorge
> 2010/7/22 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> Hi Sebastian,
>> On Wed, Jul 21, 2010 at 6:35 PM, Sebastian E. Ovide
>> >> Also, normally you will also want to retile your smaller rasters with
>> >> the
>> >> –k option to tiles (something like 100x100 or 200x200), specify the
>> >> reference system with the –s option and create an index with the –I
>> >> option.
>> >> Did you read the tutorial?
>> > it should not matter for gdal2wktraster.py right ?
>> Could you please provide a link to download the big raster that caused
>> the first problem in Linux? We're trying to reproduce it, in the same
>> conditions. You should be able to deal with big rasters by splitting
>> them into small blocks by using -k option to specify the size of the
>> blocks, and -I option to create an index, without using any other tool
>> before.
>> About the wildcard problem, we're working on it too. Thanks for reporting
>> it.
>> Best regards,
>> Jorge
>> >> Pierre
>> >> From: postgis-users-bounces at postgis.refractions.net
>> >> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> >> Sebastian E. Ovide
>> >> Sent: 21 juillet 2010 04:15
>> >> To: PostGIS Users Discussion
>> >> Subject: [postgis-users] gdal2wktraster.py wildchar not working
>> >> Hi All,
>> >> as gdal2wktraster.py has a bug that prevents importing big rasters, I
>> >> have
>> >> split the raster using
>> >> I created a lot of tif files...
>> >> then I've tried to create a sql with this:
>> >> ./gdal2wktraster.py -r test/*.tif -t newtable -o newtable.sql
>> >> and gdal2wktraster.py read only 1 file:
>> >> sebas at SeansPC:~/rasters$ ./gdal2wktraster.py -r test/*.tif -t newtable
>> >> -o
>> >> newtable.sql
>> >> Summary of GDAL to WKT Raster processing:
>> >> Number of processed raster files: 1 (test/test_01_01.tif)
>> >> List of generated tables (number of tiles):
>> >> 1 newtable (1)
>> >> any other easy way to import big rasters ?
>> >> Sebastian E. Ovide
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at postgis.refractions.net
>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> > Sebastian E. Ovide
> Sebastian E. Ovide
