[postgis-users] gdal2wktraster.py wildchar not working
Jorge Arévalo jorge.arevalo at deimos-space.com
Thu Jul 22 10:55:31 PDT 2010
I think I have a solution...
You have to specify the wildcard between quotes:
./gdal2wktraster.py -r "test/*.tif" -t newtable -o newtable.sql
instead of
./gdal2wktraster.py -r test/*.tif -t newtable -o newtable.sql
(without quotes) It worked for me on Linux. Is a shell issue, I think...
2010/7/22 Jorge Arévalo <jorge.arevalo at deimos-space.com>:
> On Thu, Jul 22, 2010 at 6:45 PM, Sebastian E. Ovide
> <sebastian.ovide at gmail.com> wrote:
>> Hi Jorge,
>>  running the same gdal2wktraster script with those options that have
>> suggested have fixed the error...
>> i.e:
>> sebas at SeansPC:~/rasters$ time ./gdal2wktraster.py -k 512x512 -s 81989 -I -r
>> raster/ -t sebastable -o ok.sql
>> ./gdal2wktraster.py:727: DeprecationWarning: integer argument expected, got
>> float
>>   hexwkb += wkblify(pt2fmt(pixtype), nodata)
>> that means that if the image is too big, "-k is mandatory" (probably it
>> should be set with some default...)
>> I have to go now.. if it gives any error I'll let you know !
>> thanks
> Great. So, we only have to focus on the wildcard problem. Keep us
> informed if you experiment more problems :-)
> Best regards,
> Jorge
>>> Hi Sebastian,
>>> On Wed, Jul 21, 2010 at 6:35 PM, Sebastian E. Ovide
>>> >> Also, normally you will also want to retile your smaller rasters with
>>> >> the
>>> >> –k option to tiles (something like 100x100 or 200x200), specify the
>>> >> reference system with the –s option and create an index with the –I
>>> >> option.
>>> >> Did you read the tutorial?
>>> > it should not matter for gdal2wktraster.py right ?
>>> Could you please provide a link to download the big raster that caused
>>> the first problem in Linux? We're trying to reproduce it, in the same
>>> conditions. You should be able to deal with big rasters by splitting
>>> them into small blocks by using -k option to specify the size of the
>>> blocks, and -I option to create an index, without using any other tool
>>> before.
>>> About the wildcard problem, we're working on it too. Thanks for reporting
>>> it.
>>> Best regards,
>>> Jorge
>>> >> Pierre
>>> >> From: postgis-users-bounces at postgis.refractions.net
>>> >> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>> >> Sebastian E. Ovide
>>> >> Sent: 21 juillet 2010 04:15
>>> >> To: PostGIS Users Discussion
>>> >> Subject: [postgis-users] gdal2wktraster.py wildchar not working
>>> >> Hi All,
>>> >> as gdal2wktraster.py has a bug that prevents importing big rasters, I
>>> >> have
>>> >> split the raster using
>>> >> I created a lot of tif files...
>>> >> then I've tried to create a sql with this:
>>> >> and gdal2wktraster.py read only 1 file:
>>> >> sebas at SeansPC:~/rasters$ ./gdal2wktraster.py -r test/*.tif -t newtable
>>> >> -o
>>> >> newtable.sql
>>> >>  Summary of GDAL to WKT Raster processing:
>>> >> Number of processed raster files: 1 (test/test_01_01.tif)
>>> >> List of generated tables (number of tiles):
>>> >> 1       newtable (1)
>>> >> any other easy way to import big rasters ?
>>> >> Sebastian E. Ovide
>>> >> _______________________________________________
>>> >> postgis-users mailing list
>>> >> postgis-users at postgis.refractions.net
>>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> > Sebastian E. Ovide
>> Sebastian E. Ovide
Jorge Arévalo
DEIMOS Space
Internet & Mobilty Division
Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
28760 Tres Cantos (Madrid)
Tel: +34 91 806 34 50 - ext: 155
http://gis4free.wordpress.com
