[postgis-users] Build topology for polygon layer using postgis2.0
Sandro Santilli
strk at keybit.net
Tue Nov 22 02:22:26 PST 2011
On Thu, Nov 03, 2011 at 04:26:26PM +0100, Sandro Santilli wrote:
> On Thu, Nov 03, 2011 at 07:09:59AM -0700, Elton Chan wrote:
> > ERROR: SQL/MM Spatial exception - non-existent node
> > CONTEXT: SQL statement "SELECT topology.ST_AddEdgeModFace(atopology, snode_id, enode_id, rec.geom)"
> This is unexpected.
> Can you share your input collection to take a look ?
> Best if you can shrink it as much as possible.
Just an heads-up on this: Elton dataset helped a lot making the
postgis topology code more robust. I hope this experience would
take others to follow the example and take their time to prepare
interesting/problematic datasets for the developers to play with.
The outcome of this experience here:
http://strk.keybit.net/blog/2011/11/21/topology-cleaning-with-postgis/
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
