[postgis-users] ST_StartPoint fails with MultiLineString
    Jose Carlos Martinez
    jomarlla at cgf.upv.es
    Thu Nov 24 08:06:20 PST 2011
Ok, I understand the strictness but what makes me confused if the mixed
policy about standards.
For example:
PostGIS 1.5 -> ST_StartPoint and ST_Endoints with Multi types are
working  (against SQL/MM)
PostGIS 2.0 -> ST_StartPoint and ST_Endoints with Multi types return
null  (folllow SQL/MM)
PostGIS 1.5 -> ST_GeometryN (geom, 1) with simple types returns null
(folllow SQL/MM)
PostGIS 2.0 -> ST_GeometryN (geom, 1) with simple types are working
(against SQL/MM)
In some cases it follows the standards but in other cases it follows the
usability.
There are more examples but I cant remember now... I think LRS functions
do not allow using Multi types with just one geometry either.
Of course we users can fix it using ST_Multi or ST_GeomeryN (geom, 1)
but I think its waste of time, code and performance. If we have to
sacrifice that because of the standards then its ok but in that case the
above example (mixed standards policy) does not make sense for me.
Regards,
On 24/11/2011 16:30, Paul Ramsey wrote:
> It's strictness. Not sure how much I like it, but that's been the
> behavior for quite a while.
> P.
> On Thu, Nov 24, 2011 at 5:39 AM, Jose Carlos Martinez
> <jomarlla at cgf.upv.es>  wrote:
>> HI,
>> p2211=# select st_startpoint ('MULTILINESTRING ((0 0, 10 0))');
>>   st_startpoint
>> (1 row)
>> returns null, according to SQL/MM  ST_StartPoint is working with ST_Curve,
>>   this is ok.  But I do not think its practical, besides previous versions of
>> PostGIS returned the first point correctly.
>> Is this a bug or PostGIS is trying to follow standards in a more strict way?
>> same with st_endpoint.
>> Cheers,
>> PD:
>> p2211=# select postgis_lib_build_date(), postgis_full_Version();
>>   postgis_lib_build_date |
>>              postgis_full_version
>>   2011-11-22 08:39:41    | POSTGIS="2.0.0SVN" GEOS="3.3.2dev-CAPI-1.7.2"
>> PROJ="Rel. 4.6.1, 21 August 2008" GDAL="GDAL 1.9dev, released 2011/01/18"
>> LIBXML="2.7.8" USE_STATS
>> (1 fila)
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
