[postgis-users] Building GEOS 3.3.1 on Ubuntu
Aren Cambre aren at arencambre.com
Sat Nov 26 21:47:13 PST 2011
I realize this is not the GEOS email group, but 3.3.1 appears to be a
prereq for running PostGIS 2.0? Ubuntu's most recent GEOS package is 3.2.2.
I can't get the builds to work. Below is a copy of the documentation bug
report I filed with the GEOS developers. What can be suggested to them to
get their instructions fixed? Or am I doing something wrong?
Aren
---------- Forwarded message ----------
Date: Sat, Nov 26, 2011 at 11:42 PM
Subject: [GEOS] #493: Bad build instructions on wiki
To:
 Reporter:  arencambre     |       Owner:  mloskot
    Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:  3.3.2
Component:  Documentation  |     Version:  3.3.1
 Severity:  Unassigned     |    Keywords:
 Both the instructions for building GEOS on Unix are bad.
 http://trac.osgeo.org/geos/wiki/BuildingOnUnixWithAutotools references an
 autogen.sh file. However, this file is not in geos-3.3.1.tar.bz2, which
 was downloaded from http://trac.osgeo.org/geos/. All that's there is
 autogen.bat.
 http://trac.osgeo.org/geos/wiki/BuildingOnUnixWithCMake also does not work
 from 3.3.1.tar.bz2. The install always fails with:
 '''CMake Error at CMakeLists.txt:161 (message):
 Detected compiler does not support std namespace on STL classes'''
 I have all requirements listed at the top of the page, verified through
 aptitude.
 This was all run on a fresh install Ubuntu 11.10 32-bit desktop version.
Ticket URL: <http://trac.osgeo.org/geos/ticket/493>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology
Suite (JTS).
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111126/94a37dfd/attachment.html>
