[postgis-users] Geocoding cross streets?
Paragon Corporation
lr at pcorp.us
Mon Nov 28 14:08:00 PST 2011
It doesn't geocode cross streets or if it is its share accident. I think
what it's doing is just picking the first one most likely so you are getting
at the beginning of a street with that name and it's ignoring the second
street at best.
The cross streets feature takes a different algorithm. We do have that
coded as a sub process in one of our projects, but it's not committed in
tiger geocoder. Feel free to post a ticket under tiger_geocoder
if you are interested in seeing it incorporated into tiger geocoder.
http://trac.osgeo.org/postgis/
Right now what we have can be relatively easily incorporated in tiger
geocoder to be a function of the form:
geocode_intersection(roadway1, roadway2, city, state, zip)
Would that work for you? I would hesitate to try to merge into the existing
geocode function since I'm not sure how much unnecessary processing that
would add if people know they aren't dealing with cross street addresses.
Thanks,
Leo and Regina
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Aren
Cambre
Sent: Monday, November 28, 2011 3:14 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Geocoding cross streets?
Hey, thanks!
I used this query:
SELECT g.rating, ST_X(geomout) AS lon, ST_Y(geomout) AS lat, (addy).* FROM
geocode('XXXX') as g;
where XXXX is replaced with strings like:
* erin and tralee, dallas, tx
* erin & tralee, dallas, tx
* sagecanyon & sagegreen, houston, tx
Those produce lat/longs that are a few miles from the correct locations.
Aren
On Mon, Nov 28, 2011 at 1:33 PM, Johnathan Leppert
<johnathan.leppert at gmail.com> wrote:
Cross-streets should be supported. Can you supply your exact query and what
versions of PostGIS and geocoder you are using?
Johnathan
On Mon, Nov 28, 2011 at 9:26 AM, Aren Cambre <aren at arencambre.com> wrote:
I have the TIGER geocoder running with PostGIS 2.0 as per
http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data.
It seems to do well finding street addresses, but it can't seem to find
cross streets. For example, if I geocode sagecanyon and sagegreen, houston,
tx, I get a location on the other side of town. Here's a Google Map showing
both: http://g.co/maps/nphp9
Can I even use the TIGER geocoder for cross streets?
Aren
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Johnathan
Software Engineer
San Francisco, California
Follow me on Twitter: <http://twitter.com/#!/iamleppert> @iamleppert
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111128/0ab16063/attachment.html>
