[postgis-users] Geocoding cross streets?
Aren Cambre
aren at arencambre.com
Wed Nov 30 16:29:02 PST 2011
Based on the conversation below, it appears there is already a solution,
and people well-versed with PostGIS may be helping with this already. Given
that, are my n00b skillz of much use?
Second question--when might this cross street feature be available? I am
asking for selfish reasons--I am working on a praxis and have thousands of
cross streets I need to geocode.
Aren
On Tue, Nov 29, 2011 at 12:03 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 11/29/2011 12:42 PM, Stephen Frost wrote:
>> * Stephen Woodbridge (woodbri at swoodbridge.com) wrote:
>>> I currently have some lists of names that are converted to optimized
>>> pcre regular expressions. I uses these to help separate the street
>>> from the city name. The lists are only used to create header files
>>> that contain the regular expressions that get compiled into the
>>> code. The idea being that these names are reasonably static for a
>>> given data set.
>> Ah, ok, I see. When converting this to a PG function, I'd probably want
>> to go ahead and pull those lists from the TIGER data set and compile the
>> regexps on PG backend startup instead. Does it handle misspelled names
>> or do any kind of "sounds like" searching on the city names? I'm
>> guessing 'no', but figured I'd ask anyway..
> The lists that I have generated are pulled from a number of sources, like
> the actual tiger data, the fips 4-2 placenames, I also have some common
> abbreviations, and misspellings, but it is not doing any sounds like
> searching. I think that I broke the regular expressions into separate state
> specific regular expressions because putting them all into a sine
> expression exceeded some limit in pcre.
> The regex expressions are created in perl and are highly optimized. You
> probably can not read the regex's and make much sense out of them, but they
> are extremely efficient to evaluate.
> Also you can take just that directory from PAGC and build it and it should
> create a command line executable that you can test with and run it in the
> debugger and valgrind, etc. Something like:
> cd parseaddress
> ./configure
> make
> ./parseaddress 101 W MLK AVE NORTH CHELMSFORD MA 01863
> -Steve
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111130/740d4a2b/attachment.html>
