[postgis-users] Populate_geometry_columns() problems
Andreas Forø Tollefsen
andreasft at gmail.com
Sat Sep 17 20:30:30 PDT 2011
This is a small database, and the populate_geometry_columns works for
all tables when i do them one at the time.
i.e. select populate_geometry_columns('public.cshapes'::regclass); returns 0.
However running this just as a populate_geometry_columns(); produces the error.
Just out of curiosity I tried with:
select populate_geometry_columns('public.raster_columns'::regclass);
which is not supposed to work? Or is it?
And this returned:
ERROR: query string argument of EXECUTE is null
CONTEXT: PL/pgSQL function "populate_geometry_columns" line 53 at
EXECUTE statement
********** Error **********
SQL state: 22004
Context: PL/pgSQL function "populate_geometry_columns" line 53 at
EXECUTE statement
Andreas
2011/9/18 Paragon Corporation <lr at pcorp.us>:
> Andreas,
> I'll take a look at this one tomorrow. Off the top of my head, I'm guessing
> you have an empty geometry table with no constraints on it so the routine
> can not guess what to set the constraints to. I'm not sure I guarded
> against that condition.
> Can you verify that doing populate_geometry_columns works for a single table
> E.g.
> SELECT populate_geometry_columns('public.mytable'::regclass);
> If you do see an empty table you can try the single call against that and I
> suspect it will fail.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas
> Forø Tollefsen
> Sent: Saturday, September 17, 2011 8:39 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Populate_geometry_columns() problems
> Hi,
> This is revision 7862.
> Just tried updating through the svn respitory.
> select postgis_full_version(); returns
> POSTGIS="2.0.0SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel. 4.7.1, 23
> September 2009" LIBXML="2.7.7" USE_STATS
> (1 row)
> Still having the same issue:
> priogrid=# select populate_geometry_columns();
> CONTEXT: PL/pgSQL function "populate_geometry_columns" line 53 at EXECUTE
> statement PL/pgSQL function "populate_geometry_columns" line 50 at
> assignment
> 2011/9/16 Sandro Santilli <strk at keybit.net>:
>> On Thu, Sep 15, 2011 at 11:25:52PM +0200, Andreas Forø Tollefsen wrote:
>>> Hi all,
>>> Trying to do a populate_geometry_columns(); but it does not work.
>>> This is PostGis 2.0 with Gdal 1.8, Geos 3.4
>> Revision number ?
>>> Command: SELECT Populate_Geometry_Columns();
>>> EXECUTE statement PL/pgSQL function "populate_geometry_columns" line
>>> 50 at assignment
>>> Any ideas?
>> Update to latest trunk revision, make sure to re-source postgis.sql,
>> try again. If the problem persists please file ticket.
>> --strk;
>> () Free GIS & Flash consultant/developer
>> /\ http://strk.keybit.net/services.html
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
