[postgis-users] Populate_geometry_columns() problems
Andreas Forø Tollefsen
andreasft at gmail.com
Sat Sep 17 23:06:43 PDT 2011
Tonight I did a full reinstall of Ubuntu 11.04 and reinstalled the
postgresql and postgis.
"POSTGIS="2.0.0SVN" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.7.8" USE_STATS"
This is also rev 7862.
The same error exists,
ERROR: query string argument of EXECUTE is null
CONTEXT: PL/pgSQL function "populate_geometry_columns" line 53 at
EXECUTE statement
PL/pgSQL function "populate_geometry_columns" line 50 at assignment
********** Error **********
SQL state: 22004
Context: PL/pgSQL function "populate_geometry_columns" line 53 at
EXECUTE statement
while this works fine:
select populate_geometry_columns('public.cshapes'::regclass);
0
2011/9/17 Andreas Forø Tollefsen <andreasft at gmail.com>:
> Hi,
> This is a small database, and the populate_geometry_columns works for
> all tables when i do them one at the time.
> i.e. select populate_geometry_columns('public.cshapes'::regclass); returns 0.
> However running this just as a populate_geometry_columns(); produces the error.
> Just out of curiosity I tried with:
> select populate_geometry_columns('public.raster_columns'::regclass);
> which is not supposed to work? Or is it?
> And this returned:
> EXECUTE statement
> SQL state: 22004
> EXECUTE statement
> Andreas
> 2011/9/18 Paragon Corporation <lr at pcorp.us>:
>> Andreas,
>> I'll take a look at this one tomorrow. Off the top of my head, I'm guessing
>> you have an empty geometry table with no constraints on it so the routine
>> can not guess what to set the constraints to. I'm not sure I guarded
>> against that condition.
>> Can you verify that doing populate_geometry_columns works for a single table
>> E.g.
>> SELECT populate_geometry_columns('public.mytable'::regclass);
>> If you do see an empty table you can try the single call against that and I
>> suspect it will fail.
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas
>> Forø Tollefsen
>> Sent: Saturday, September 17, 2011 8:39 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] Populate_geometry_columns() problems
>> Hi,
>> This is revision 7862.
>> Just tried updating through the svn respitory.
>> select postgis_full_version(); returns
>> POSTGIS="2.0.0SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel. 4.7.1, 23
>> September 2009" LIBXML="2.7.7" USE_STATS
>> (1 row)
>> Still having the same issue:
>> priogrid=# select populate_geometry_columns();
>> CONTEXT: PL/pgSQL function "populate_geometry_columns" line 53 at EXECUTE
>> statement PL/pgSQL function "populate_geometry_columns" line 50 at
>> assignment
>> 2011/9/16 Sandro Santilli <strk at keybit.net>:
>>> On Thu, Sep 15, 2011 at 11:25:52PM +0200, Andreas Forø Tollefsen wrote:
>>>> Hi all,
>>>> Trying to do a populate_geometry_columns(); but it does not work.
>>>> This is PostGis 2.0 with Gdal 1.8, Geos 3.4
>>> Revision number ?
>>>> Command: SELECT Populate_Geometry_Columns();
>>>> EXECUTE statement PL/pgSQL function "populate_geometry_columns" line
>>>> 50 at assignment
>>>> Any ideas?
>>> Update to latest trunk revision, make sure to re-source postgis.sql,
>>> try again. If the problem persists please file ticket.
>>> --strk;
>>> () Free GIS & Flash consultant/developer
>>> /\ http://strk.keybit.net/services.html
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
