[postgis-users] Populate_geometry_columns() problems
Paragon Corporation
lr at pcorp.us
Sun Sep 18 07:57:47 PDT 2011
Andreas,
I had forgotten to exclude raster_columns (fixed now), but the fundamental
problem was that
empty geometry tables weren't being handled correctly. I suspect
raster_columns was probably the only
empty table with a geometry column in your database.
Should all be fixed now.
Thanks for reporting,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Andreas Forø Tollefsen
> Sent: Sunday, September 18, 2011 2:07 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Populate_geometry_columns() problems
> Tonight I did a full reinstall of Ubuntu 11.04 and
> reinstalled the postgresql and postgis.
> "POSTGIS="2.0.0SVN" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1,
> 23 September 2009" LIBXML="2.7.8" USE_STATS"
> This is also rev 7862.
> The same error exists,
> ERROR: query string argument of EXECUTE is null
> CONTEXT: PL/pgSQL function "populate_geometry_columns" line
> 53 at EXECUTE statement PL/pgSQL function
> "populate_geometry_columns" line 50 at assignment
> ********** Error **********
> ERROR: query string argument of EXECUTE is null SQL state: 22004
> Context: PL/pgSQL function "populate_geometry_columns" line
> while this works fine:
> select populate_geometry_columns('public.cshapes'::regclass);
> 0
> 2011/9/17 Andreas Forø Tollefsen <andreasft at gmail.com>:
> > Hi,
> > This is a small database, and the populate_geometry_columns
> works for
> > all tables when i do them one at the time.
> > i.e. select
> populate_geometry_columns('public.cshapes'::regclass); returns 0.
> > However running this just as a populate_geometry_columns();
> produces the error.
> > Just out of curiosity I tried with:
> > select populate_geometry_columns('public.raster_columns'::regclass);
> > which is not supposed to work? Or is it?
> > And this returned:
> > CONTEXT: PL/pgSQL function "populate_geometry_columns" line 53 at
> > EXECUTE statement
> > Context: PL/pgSQL function "populate_geometry_columns" line 53 at
> > EXECUTE statement
> > Andreas
> > 2011/9/18 Paragon Corporation <lr at pcorp.us>:
> >> Andreas,
> >> I'll take a look at this one tomorrow. Off the top of my
> head, I'm
> >> guessing you have an empty geometry table with no
> constraints on it
> >> so the routine can not guess what to set the constraints
> to. I'm not
> >> sure I guarded against that condition.
> >> Can you verify that doing populate_geometry_columns works for a
> >> single table
> >> E.g.
> >> SELECT populate_geometry_columns('public.mytable'::regclass);
> >> If you do see an empty table you can try the single call
> against that
> >> and I suspect it will fail.
> Behalf Of
> >> Sent: Saturday, September 17, 2011 8:39 PM
> >> Hi,
> >> This is revision 7862.
> >> Just tried updating through the svn respitory.
> >> select postgis_full_version(); returns
> >> POSTGIS="2.0.0SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel.
> 4.7.1, 23
> >> September 2009" LIBXML="2.7.7" USE_STATS
> >> (1 row)
> >> Still having the same issue:
> >> priogrid=# select populate_geometry_columns();
> >> 50 at assignment
> >> 2011/9/16 Sandro Santilli <strk at keybit.net>:
> >>> On Thu, Sep 15, 2011 at 11:25:52PM +0200, Andreas Forø
> Tollefsen wrote:
> >>>> Hi all,
> >>>> Trying to do a populate_geometry_columns(); but it does not work.
> >>>> This is PostGis 2.0 with Gdal 1.8, Geos 3.4
> >>> Revision number ?
> >>>> Command: SELECT Populate_Geometry_Columns();
> line 53 at
> >>>> EXECUTE statement PL/pgSQL function "populate_geometry_columns"
> >>>> Any ideas?
> >>> Update to latest trunk revision, make sure to re-source
> postgis.sql,
> >>> try again. If the problem persists please file ticket.
> >>> --strk;
> >>> () Free GIS & Flash consultant/developer
> >>> /\ http://strk.keybit.net/services.html
> >>> _______________________________________________
> >>> postgis-users mailing list
> >>> postgis-users at postgis.refractions.net
> >>> http://postgis.refractions.net/mailman/listinfo/postgis-users
