[postgis-users] ST_Insersection problem
strk at keybit.net
strk at keybit.net
Thu Sep 22 01:47:29 PDT 2011
On Wed, Sep 21, 2011 at 11:49:22PM -0700, G. van Es wrote:
> Well, omitting hundreds or thousands from the source of over 11 million isn't something i can do. The procedure should run in batch, otherwise i would use Qgis which does the same job in an hour.
> So, i am still looking for a sql solution.......
You'll need a scripting language, either within or external to the DB.
Can't do in SQL only with current postgis.
This being a frequently recurring complaint, it may be a good idea
allowing for a configuration setting or additional arguments to make
topological operations return NULL on robustness issues rather than
throwin an exception.
I could work on that if someone is willing to sponsor the work.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
