[postgis-users] PostGIS installation in Windows 32-bit
Paragon Corporation
lr at pcorp.us
Wed Sep 28 03:07:40 PDT 2011
Arto,
You can't use postgresql 9.1.1-windows with postgis-pg90-binaries-1.5.3.
zip. Those are incompatible.
We have builds for upcoming PostGIS 2.0 for PostgreSQL 9.1 windows which
will work together. In the experimental section:
http://www.postgis.org/download/windows/experimental.php#PostGIS_2_0_0
We were hoping that PostGIS 2.0 would be released before PostgreSQL 9.1 so
that we wouldn't have to produce PostGIS 1.5 binaries for PostgreSQL 9.1.
given that that
didn't happen and PostGIS 2.0 will be months from now, I guess we'll need to
produce 1.5.3 binaries :(.
If you can wait till this weekend or Monday, we should have new batches of
binaries ready for 1.5.3 (Pg 9.1) and PostGIS 2.0 (Pg 9.1).
The PostGIS 2.0 -- next batch we release which we hope to do in the next day
or so will include the new KNN GIST support for 9.1
and new raster / raster intersects functions.
or you can stay on the stable less fun side and wait till this weekend or
Monday for us to prepare the 1.5.3 (Pg 9.1 builds).
-- Regarding:
"5) Just wondering: to create a PostGIS enabled database, is the
makepostgisdb.bat usage a must? Last year at least it was possible to use
PostGIS template in PgAdmin III to create a new database."
The makepostgisdb.bat can make a template database for you. You just have
to change the variables in there and unremark out the update template line.
Hope that helps,
Regina and Leo
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Arto
Vuorela
Sent: Wednesday, September 28, 2011 5:48 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS installation in Windows 32-bit
Hello
I aim to use postgresql-9.1.1-1-windows.exe and
postgis-pg90-binaries-1.5.3.zip (aiming to use with zigGIS, PgMap or ArcGIS
10.1, map service). Some basic questions for Windows Server 2003
installation:
1) PostGIS manuals say "A complete installation of PostgreSQL (including
server headers) is required." Were the server headers automatically
installed? I chose PgOleDB, pgJDBC and psqlODBC database drivers for
PostgreSQL, if that matters.
2) Should I worry also about this (from the manual as well)?:
For GEOS functionality, when you install PostgresSQL you may need to
explicitly link PostgreSQL against the standard C++ library:
LDFLAGS=-lstdc++ ./configure [YOUR OPTIONS HERE]
3) PostGIS JDBC driver I understand to be different from PostgreSQL JDBC
driver.
<http://postgis.refractions.net/pipermail/postgis-devel/2006-November/002375
.html>
http://postgis.refractions.net/pipermail/postgis-devel/2006-November/002375.
html says Versions 1.1.5 and 1.1.6 of the PostGIS-JDBC-Drivers are available
at
<http://lists.refractions.net/m2/org/postgis>
http://lists.refractions.net/m2/org/postgis. Someone also mentioned in
discussions that he found postgis-jdbc 1.3.5 on public Maven repositories.
What is Maven or Pom I don't even know. Those all may be old - should I use
the non-debug jar version at JDBC SNAPSHOT on page
http://postgis.refractions.net/download/? Where should the chosen version be
installed, or how? By merely listing it in CLASSPATH variable, as the
PostgreSQL JDBC driver? The PostGIS's README.txt does not tell such things.
4) As PostGIS is not found under Stack Builder yet for 9.1, I should put the
binaries in correct places. Are the postgis-pg90-binaries-1.5.3 contents put
in the installation folder (...\PostgreSQL\9.1\, so that most files go under
the three subfolders)? The README.txt does not tell this either.
Arto
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110928/461b1a81/attachment.html>
