[postgis-users] Moving to a Virtual Server
Gerry Creager - NOAA Affiliate
gerry.creager at noaa.gov
Wed Jul 29 07:38:22 PDT 2015
You can use DNS to alias new machine names, so they appear to users as the
old ones, or, you can simply transfer the old names to the new instances.
Your "consultant" should have answered all of these questions, though. I
strongly recommend you and management revisit the issue with them, and if
you can't get the answers you need, get a new consutlatnt. Quickly.
With the exception of the PostGIS-related immediate issue, your question is
a little scary. It focuses on what I consider basic system administration
skills, and should be something your sys admin knows cold. If (s)he has an
opinion, respect it. If you've already lost them in the consultant process,
you could be in trouble.
Gerry
On Tue, Jul 28, 2015 at 4:50 PM, Raoul Ross <RRoss at continentalmapping.com>
wrote:
> Hello, my name is Raoul Ross and I’ve taken over for Eric VanHandel as
> the IT Manager here at Continental Mapping Consultants.
> Through a vendor/Consultant we are moving off the very old servers here to
> Virtual Servers. The question came up, ‘can we just copy it all over, using
> the same machine name, IP address and NIC MAC Address?’ So I’m asking… will
> it work? If not, how do I do this? Will I need to re-install everything?
> Don’t know where else to start… Thanx for your time!
> -Raoul Ross
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Gerry Creager
NSSL/CIMMS
405.325.6371
“Big whorls have little whorls,
That feed on their velocity;
And little whorls have lesser whorls,
And so on to viscosity.”
Lewis Fry Richardson (1881-1953)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150729/b1ed0e6c/attachment.html>
