[postgis-users] Moving to a Virtual Server
Raoul Ross
RRoss at continentalmapping.com
Wed Jul 29 08:09:14 PDT 2015
From what I am seeing from other vendors, a License File is created using the server’s hardware in the creation process. From your response, I gather that the PostGIS/PostGRE software doesn’t require that. I will just reinstall from scratch then.
Raoul
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Gerry Creager - NOAA Affiliate
Sent: Wednesday, July 29, 2015 9:38 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Moving to a Virtual Server
You can use DNS to alias new machine names, so they appear to users as the old ones, or, you can simply transfer the old names to the new instances. Your "consultant" should have answered all of these questions, though. I strongly recommend you and management revisit the issue with them, and if you can't get the answers you need, get a new consutlatnt. Quickly.
With the exception of the PostGIS-related immediate issue, your question is a little scary. It focuses on what I consider basic system administration skills, and should be something your sys admin knows cold. If (s)he has an opinion, respect it. If you've already lost them in the consultant process, you could be in trouble.
Gerry
On Tue, Jul 28, 2015 at 4:50 PM, Raoul Ross <RRoss at continentalmapping.com<mailto:RRoss at continentalmapping.com>> wrote:
Hello, my name is Raoul Ross and I’ve taken over for Eric VanHandel as the IT Manager here at Continental Mapping Consultants.
Through a vendor/Consultant we are moving off the very old servers here to Virtual Servers. The question came up, ‘can we just copy it all over, using the same machine name, IP address and NIC MAC Address?’ So I’m asking… will it work? If not, how do I do this? Will I need to re-install everything?
Don’t know where else to start… Thanx for your time!
-Raoul Ross
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Gerry Creager
NSSL/CIMMS
405.325.6371
“Big whorls have little whorls,
That feed on their velocity;
And little whorls have lesser whorls,
And so on to viscosity.”
Lewis Fry Richardson (1881-1953)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150729/1ceb89cb/attachment.html>
