[postgis-users] Queries on partitioned table not behaving as expected
Nicolas Ribot
nicolas.ribot at gmail.com
Mon Nov 2 10:53:15 PST 2015
AFAIU, the restriction on partitioned tables is even bigger. From PG doc (
http://www.postgresql.org/docs/current/interactive/ddl-partitioning.html#DDL-PARTITIONING-CONSTRAINT-EXCLUSION)
"The following caveats apply to constraint exclusion:
Constraint exclusion only works when the query's WHERE clause contains
constants (or externally supplied parameters). For example, a comparison
against a non-immutable function such asCURRENT_TIMESTAMP cannot be
optimized, since the planner cannot know which partition the function value
might fall into at run time.
Using a subquery to provide values won't trigger the constraint exclusion.
One solution could be an anonymous block or a function to explicitly write
query with constant values got from a previous query.
Rubio, take also care that a lot of partitioned tables is not recommended
by Pg doc:
"All constraints on all partitions of the master table are examined during
constraint exclusion, so large numbers of partitions are likely to increase
query planning time considerably. Partitioning using these techniques will
work well with up to perhaps a hundred partitions; don't try to use many
thousands of partitions."
I would go for a smaller set of bigger tables (10's millions rows or so).
Nicolas
On 2 November 2015 at 18:28, Bborie Park <dustymugs at gmail.com> wrote:
> That check constraint is not going to help you as it is too complicated
> for the partitioning task. I don't believe the partitioning constraint can
> be functional but needs to be simpler and built upon a basic data type...
> Something like...
> CREATE TABLE max_extent AS (
> id integer PRIMARY KEY,
> geom geometry(POLYGON)
> And then the parent/partition tables had a reference to pc_extent...
> CREATE TABLE ahn3_pointcloud.ahn3_all
> id integer NOT NULL,
> pa pcpatch(7),
> max_extent_id integer
> Then your queries become...
> WITH max_extents AS (
> SELECT
> id
> FROM max_extent
> WHERE PC_Intersects(geom, ST_MakeEnvelope(120740,486076,121074,486292,
> 28992))
> SELECT
> FROM ahn3_all
> JOIN max_extents
> ON ahn3_all.max_extent_id = max_extents.id
> -bborie
> On Mon, Nov 2, 2015 at 8:45 AM, Rubio Vaughan <rubio.vaughan at geodan.nl>
> wrote:
>> Dear all,
>> We are trying to load a large LIDAR pointcloud dataset into multiple
>> tables in PostGIS, using the point cloud extension. Eventually the whole
>> data set will consist of 1400+ tables, containing about 1 million records
>> each. Using a union view on all these tables would result in terrible
>> performance, which is why we are trying to optimize query performance using
>> partitioned tables. According to the documentation, the use of partitioned
>> tables with CHECK constraints should cause the query planner to only scan
>> those tables for which the CHECK constraint matches. Excerpt from the
>> documentation:
>> *18.7.4. Other Planner Options*
>> constraint_exclusion (enum): Controls the query planner's use of table
>> constraints to optimize queries. The allowed values of constraint_exclusion
>> are on (examine constraints for all tables), off (never examine
>> constraints), and partition (examine constraints only for inheritance child
>> tables and UNION ALL subqueries). partition is the default setting. It is
>> often used with inheritance and partitioned tables to improve performance.
>> When this parameter allows it for a particular table, the planner compares
>> query conditions with the table's CHECK constraints, and omits scanning
>> tables for which the conditions contradict the constraints.
>> However, as you can see from the example query below, the indexes for all
>> child tables are still scanned. I would expect the query planner to only
>> scan table c_25gn1, which contains the queried region. Does anyone here
>> have experience with partitioned tables? I would be delighted to get some
>> pointers for figuring out this problem.
>> Thanks in advance for any help!
>> Best regards,
>> Rubio Vaughan
>> *General info:*
>> SELECT postgis_full_version();
>> "POSTGIS="2.2.0 r14208" GEOS="3.5.0-CAPI-1.9.0 r4084" SFCGAL="1.2.0"
>> PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 2.0.1, released 2015/09/15"
>> LIBXML="2.9.1" LIBJSON="0.11.99" TOPOLOGY (topology procs from "2.1.4
>> r12966" need upgrade) RASTER"
>> SHOW "constraint_exclusion";
>> "partition"
>> *The parent table:*
>> pa pcpatch(7)
>> *One of the child tables:*
>> CREATE TABLE ahn3_pointcloud.c_25dn2
>> id serial NOT NULL,
>> pa pcpatch(7),
>> CONSTRAINT c_25dn2_pkey PRIMARY KEY (id),
>> CONSTRAINT check_extent CHECK (pc_intersects(pa,
>> st_geomfromtext('POLYGON((115000 487500,120000 487500,120000 481250,115000
>> 481250,115000 487500))'::text, 28992)))
>> INHERITS (ahn3_pointcloud.ahn3_all)
>> *Example query:*
>> EXPLAIN SELECT COUNT(pa) FROM ahn3_pointcloud.ahn3_all
>> WHERE PC_Intersects(pa, ST_MakeEnvelope(120740,486076,121074,486292,
>> 28992))
>> "Aggregate (cost=301989.36..301989.37 rows=1 width=32)"
>> " -> Append (cost=0.00..301248.82 rows=296216 width=32)"
>> " -> Seq Scan on ahn3_all (cost=0.00..0.00 rows=1 width=32)"
>> " Filter:
>> (('010300002040710000010000000500000000000000407AFD4000000000<snip>
>> " -> Bitmap Heap Scan on c_25gn1 (cost=6064.85..59546.09
>> rows=58574 width=32)"
>> " Recheck Cond:
>> ('010300002040710000010000000500000000000000407AFD40000<snip>
>> " Filter:
>> _st_intersects('010300002040710000010000000500000000000000407<snip>
>> " -> Bitmap Index Scan on c_25gn1_idx (cost=0.00..6050.20
>> rows=175722 width=0)"
>> " Index Cond:
>> ('010300002040710000010000000500000000000000407AFD4<snip>
>> " -> Bitmap Heap Scan on c_30fz1 (cost=7990.39..77907.99
>> rows=76576 width=32)"
>> " Recheck Cond:
>> " Filter:
>> " -> Bitmap Index Scan on c_30fz1_idx (cost=0.00..7971.24
>> rows=229727 width=0)"
>> " Index Cond:
>> " -> Bitmap Heap Scan on c_30fz2 (cost=7393.57..71499.52
>> rows=70210 width=32)"
>> " Recheck Cond:
>> " Filter:
>> " -> Bitmap Index Scan on c_30fz2_idx (cost=0.00..7376.02
>> rows=210631 width=0)"
>> " Index Cond:
>> " -> Bitmap Heap Scan on c_25ez1 (cost=2624.69..26079.63
>> rows=25688 width=32)"
>> " Recheck Cond:
>> " Filter:
>> " -> Bitmap Index Scan on c_25ez1_idx (cost=0.00..2618.27
>> rows=77064 width=0)"
>> " Index Cond:
>> " -> Bitmap Heap Scan on c_25dn2 (cost=6714.83..66215.58
>> rows=65167 width=32)"
>> " Recheck Cond:
>> " Filter:
>> " -> Bitmap Index Scan on c_25dn2_idx (cost=0.00..6698.54
>> rows=195500 width=0)"
>> " Index Cond:
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151102/ec1d42ee/attachment.html>
