[postgis-users] New day, new problem - now with pl/r
Paragon Corporation
lr at pcorp.us
Sun Nov 8 11:58:48 PST 2015
Darrel,
Hah. Well you managed to find Environment Variables so can't be that much
of an idiot. Takes me ages to find it since they keep on moving it on
whatever windows version I am on.
One other thing to verify? Do you have the R_HOME variable set?
Should be set to - C:\Program Files\R\R-3.2.2
And it should be set in the System section instead of User section. Though
mine is set in User section since I have PostgresQL running under a
privileged account so it can access other computer network resources.
The
SELECT * FROM r_typenames();
Takes 47-62 ms on my windows 2012 R2 server and returns: 194 rows
I just noticed something really odd though. If I run it in pgAdmin Query
window it runs fine and returns
ABSTIMEOID;702
ACLITEMOID;1033
But then I tried rerunning in psql to get a nicer output, and got this
ERROR: R interpreter expression evaluation error
DETAIL: Error in data.frame(typename = x, typeoid = y) :
arguments imply differing number of rows: 0, 1
CONTEXT: In PL/R function r_typenames
Then I tried again in pgAdmin guessing it might be the paging in psql that
is tripping, and voila, if I do
SELECT * FROM r_typenames() LIMIT 10;
In pgAdmin query window, I also stumble on the error. So something is
definitely fishy there and you might be just really good at tripping on bugs
BTW the list for PL/R questions is -
http://lists.pgfoundry.org/mailman/listinfo/plr-general
Though I thought most things were moving away from pgFoundry since pgFoundry
will be retired soon, so the list might be in flux.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Darrel Maddy
Sent: Sunday, November 08, 2015 12:50 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] New day, new problem - now with pl/r
Dear Regina,
The path is set to C:\Program Files\R\R-3.2.2\bin\x64\ and it is picking
this up as this is shown in the output from the SELECT * FROM
plr_environ();
The service has been restarted several times.
I am running postgres 9.4.4 build 1800 64bit and plr 8.0.3.16. Strangely I
have the same issue on both my laptop and workstation. As you have no issues
I have clearly done something wrong (it seems your idiot proof guide may not
be idiot proof!). I will take a fresh look and try to see where I have gone
wrong. How long should the query take?
Best wishes
Darrel
Of Paragon Corporation
Sent: 8 November, 2015 5:30 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org
<mailto:postgis-users at lists.osgeo.org> >
Darrel,
Hmm that would suggest you might have the R-path wrong. Those statements
should all be pretty fast
As noted in article,
If you are running R version 2.12 or above on Windows, the R bin folder has
changed. Instead of bin it's bin\i386 or bin\x64
Also you want to make sure you restart postgres service after setting the
environment variables, since it doesn't take effect until relaunch.
Which version of R are you running? I'm running R 3.2.2 x64 with PostgreSQL
9.4.5, compiled by Visual C++ build 1800, 64-bit and plr 8.3.0.16
It's possible things have changed since I installed, but all those commands
work pretty fast on my database.
Thanks,
Regina
http://www.postgis.us
http://postgis.net
Of Darrel Maddy
Sent: Sunday, November 08, 2015 10:23 AM
Subject: [postgis-users] New day, new problem - now with pl/r
Dear all,
Not sure if this is the right place to ask this but.
I have just installed the plr extension using the instructions given here:
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tu
t01
Setting both the path and R_Home variables.
The extension shows up in PGAdmin for this database.
I tried to check the installation using the suggested commands
SELECT * FROM plr_environ();
SELECT load_r_typenames();
SELECT plr_array_accum('{23,35}', 42);
The first of these runs but the second command seems to go into an endless
loop (I stopped this after one hour- I assume it should not take that
long?). I assume the failure to finish means there is a problem seeing the r
typenames? As it does not fall over there is no error message to help.
I am open to any suggestions how to proceed.
Darrel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151108/51d947e3/attachment.html>
