[postgis-users] restore problem
Bborie Park dustymugs at gmail.com
Tue Nov 10 14:19:41 PST 2015
Odd. Looking at your error message again, it looks like the constraint is
already in place by the time the data is getting loaded...
What are you restoring from? Tar, custom or text?
On Tue, Nov 10, 2015 at 2:16 PM, Darrel Maddy <darrel.maddy at newcastle.ac.uk>
wrote:
> Dear Bborie,
> Apologies, I was obviously not clear – I was not asking about the problem
> itself, I can accept this is a difficult problem to resolve. I was simply
> asking for instruction on how to use your work around. This you kindly
> provided. Alas, however, even with the boxes checked, I get the same error
> and the raster table (dems) is empty.
> Darrel
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Bborie Park
> *Sent:* 10 November 2015 21:57
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] restore problem
> Given that the core problem has to do with the restore process'
> search_path, no amount of advice will help you get around the restrictions
> in place with the restore process without jumping into that process.
> In pgAdmin, you can check the boxes "Pre-data" and "Data" of the "Restore
> Options #1" tab. This won't restore the post-data portion of the backup as
> restoring post-data should be causing your error.
> You could also try unchecking the box "Exit On Error" of the "Restore
> Options #2" tab.
> -bborie
> On Tue, Nov 10, 2015 at 1:29 PM, Darrel Maddy <
> darrel.maddy at newcastle.ac.uk> wrote:
> Dear Bborie,
> Yikes – that makes little sense to me.  I am new to both postgres and
> postgis and would have hoped that backup and restore would have been simple
> push-button exercise!
> As I am using PgAdmin I have no idea how to follow your instructions L
> Anyone care to give me an idiots guide?
> Sorry
> Darrel
> *Sent:* 10 November 2015 21:22
> This problem arises because PostgreSQL sets the search path during the
> restore process. Unfortunately, the search path is quite restrictive.
> You should be able to do your restore in three sections using pg_restore's
> --section flag.
> The error looks like it has to be the post-data section, which you should
> output to a text file, change the "SET search_path" statements and then run
> through psql.
> -bborie
> On Tue, Nov 10, 2015 at 1:11 PM, Darrel Maddy <
> Dear all,
> Like many here I suspect I want to keep a copy of my main databases held
> on my workstation, on my laptop. I used PgAdmin to backup the databases
> concerned (the backup files look about the size I was expecting)  but
> restore on my laptop did not successfully complete.  All my shp file tables
> restored without issues but my raster tables (these are tiled rasters)
> would not. Looking at the error in the restore window of PgAdmin this
> appears to be a problem with a function/constraint.
> pg_restore: processing data for table "dems"
> pg_restore: [archiver (db)] Error while PROCESSING TOC:
> pg_restore: [archiver (db)] Error from TOC entry 3459; 0 94054 TABLE DATA
> dems postgres
> pg_restore: [archiver (db)] COPY failed for table "dems": ERROR:  function
> st_bandmetadata(public.raster, integer[]) does not exist
> LINE 1:  SELECT array_agg(pixeltype)::text[] FROM st_bandmetadata($1...
> HINT:  No function matches the given name and argument types. You might
> need to add explicit type casts.
> QUERY:   SELECT array_agg(pixeltype)::text[] FROM st_bandmetadata($1,
> ARRAY[]::int[]);
> CONTEXT:  SQL function "_raster_constraint_pixel_types" during inlining
> COPY dems, line 1: "1
> 0100000100000000000000344000000000000034C0E0CCCCCCB1D517418066666692F80C41000000000000000000000000..."
> I did a quick search and found some old chatter on this issue but from the
> messages I read I would have expected this issue to have been cleared up in
> postgis 2 .
> Obviously I cannot contemplate having mission critical data in a database
> which does not backup/restore correctly so I am assuming there is a fix
> which avoids this issue or there is another way to make a copy of the
> database for transfer elsewhere?
> Once again any help would be gratefully received.
> Best wishes
> Darrel
> ps.   Apologies for the string of questions I have asked lately – I will
> go silent once more shortly as I must move on to other things.
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151110/abe64413/attachment.html>
