[postgis-users] restore problem
Darrel Maddy darrel.maddy at newcastle.ac.uk
Thu Nov 12 05:15:20 PST 2015
OK trying this again without the prior messages to avoid the max limits.
Apologies if my original appears, when I tried to cancel the posting it seemed to ask for a ‘cookie’ code I did not have!
Anyhow, thanks to everyone.
D
Sent: 12 November 2015 09:51
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: RE: [postgis-users] restore problem
Dear  Regina,
Many thanks again for this detailed explanation – this really does help me understand what is happening.  I did not have the clean flag set BUT when I tried this again this morning it has worked ☺. I have tried this on two databases now and both seem to have restored the raster data. Clearly I would not have figured this out without your instruction! It is a shame that this process is not as easy as I am sure everyone would like it to be but the workaround is simple once you know how and as long as this is documented I don’t see this as a deal breaker.
On one of my databases I do get a new (presumably trivial) error:
pg_restore: processing data for table "spatial_ref_sys"
pg_restore: [archiver (db)] Error while PROCESSING TOC:
pg_restore: [archiver (db)] Error from TOC entry 3303; 0 35941 TABLE DATA spatial_ref_sys postgres
pg_restore: [archiver (db)] COPY failed for table "spatial_ref_sys": ERROR:  duplicate key value violates unique constraint "spatial_ref_sys_pkey"
DETAIL:  Key (srid)=(5013) already exists.
This only happened on the second database I tried to restore and it may not be a significant issue. Should I ignore this?
Many thanks again from a very relieved
Darrel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151112/98c5ce25/attachment.html>
