[postgis-users] Unable to install PostgreSQL 9.5.11 on Windows 10
Jibran Khan
jibran at envs.au.dk
Tue Apr 17 04:09:02 PDT 2018
Hello,
Apologies if this is an irrelevant question, here.
I have been trying to install PostgreSQL 9.5.11 on Windows 10 (x64) using Enterprise DB interactive installer. But, no success.
I keep getting this error.
[cid:image001.png at 01D3D64D.3E2ABB10]
I am aware about the BigSQL installers but I prefer the Enterprise DB one :).
I came across the similar issue here:
https://stackoverflow.com/questions/46118851/unable-to-install-postgresql-on-windows-10
A little googling routed me towards some proposed solutions (here<http://1stopit.blogspot.dk/2011/01/postgresql-83-and-84-fails-to-install.html> and here<https://serverfault.com/questions/230219/vbscript-wont-run-for-domain-user-on-windows-server-2008-r2>).
I tried them but, no success.
Here is the error message, I am getting.
Can somebody suggest the workaround to fix this issue?
Log started 04/17/2018 at 11:28:34
Preferred installation mode : qt
Trying to init installer in mode qt
Mode qt successfully initialized
Executing C:\my_user\AppData\Local\Temp/postgresql_installer_676baef523/temp_check_comspec.bat
Script exit code: 0
Script output:
"test ok"
Script stderr:
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Data Directory. Setting variable iDataDirectory to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Base Directory. Setting variable iBaseDirectory to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Service ID. Setting variable iServiceName to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Service Account. Setting variable iServiceAccount to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Super User. Setting variable iSuperuser to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Branding. Setting variable iBranding to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Version. Setting variable brandingVer to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Shortcuts. Setting variable iShortcut to empty value
Could not find registry key HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 DisableStackBuilder. Setting variable iDisableStackBuilder to empty value
[11:28:39] Existing base directory:
[11:28:39] Existing data directory:
[11:28:39] Using branding: PostgreSQL 9.5
[11:28:39] Using Super User: postgres and Service Account: NT AUTHORITY\NetworkService
[11:28:39] Using Service Name: postgresql-x64-9.5
Executing cscript //NoLogo "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs"
Script exit code: 1
Script output:
CScript Error: Loading script "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs" failed (Access is denied. ).
Script stderr:
Program ended with an error exit code
Error running cscript //NoLogo "C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks.vbs": Program ended with an error exit code
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180417/ef1dc559/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180417/ef1dc559/attachment.png>
