[postgis-users] Postgis upgrade from 2.4.6 to 2.5
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Thu Dec 6 01:43:40 PST 2018
Checking whether upgrade path is supported is easy: you open your source
package and look up your "from" version in upgradeable_versions.mk file in
extensions directory. 2.5.1 contains a record for upgrading from 2.4.6.
On Thu, Dec 6, 2018 at 11:05 AM Ahsan Hadi <ahsan.hadi at enterprisedb.com>
wrote:
> On Wed, Dec 5, 2018 at 5:53 PM Ahsan Hadi <ahsan.hadi at enterprisedb.com>
> wrote:
>> On Wed, Dec 5, 2018 at 3:55 PM Darafei "Komяpa" Praliaskouski <
>> me at komzpa.net> wrote:
>>> Hi Ashan,
>>> PostGIS 2.4.6 was released after PostGIS 2.5.0. You need to upgrade to
>>> 2.5.1 that was released after 2.4.6.
>> Okay so they will upgrade to postgis 2.5.1 from postgis 2.4.6?
> Is this supported upgrade path?
>>> On Wed, Dec 5, 2018 at 1:50 PM Ahsan Hadi <ahsan.hadi at enterprisedb.com>
>>> wrote:
>>>> Hi Regina,
>>>> Do you know if a user running postgis 2.4.6 with PG 11 can upgrade to
>>>> postgis 2.5 with v11 using the alter extension command? We are currently
>>>> seeing the error below, this could be a setup issue but i wanted to confirm
>>>> whether this upgrade path is officially supported.
>>>> db1=# ALTER EXTENSION Postgis UPDATE;
>>>> ERROR: extension "postgis" has no update path from version "2.4.6" to
>>>> version "2.5.0"
>>>> Thanks,
>>>> Ahsan Hadi
>>>> Snr Director Product Development
>>>> EnterpriseDB Corporation
>>>> The Enterprise Postgres Company
>>>> Phone: +92-51-8358874
>>>> Mobile: +92-333-5162114
>>>> Website: www.enterprisedb.com
>>>> EnterpriseDB Blog: http://blogs.enterprisedb.com/
>>>> Follow us on Twitter: http://www.twitter.com/enterprisedb
>>>> This e-mail message (and any attachment) is intended for the use of the
>>>> individual or entity to whom it is addressed. This message contains
>>>> information from EnterpriseDB Corporation that may be privileged,
>>>> confidential, or exempt from disclosure under applicable law. If you are
>>>> not the intended recipient or authorized to receive this for the intended
>>>> recipient, any use, dissemination, distribution, retention, archiving, or
>>>> copying of this communication is strictly prohibited. If you have received
>>>> this e-mail in error, please notify the sender immediately by reply e-mail
>>>> and delete this message.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>> Darafei Praliaskouski
>>> Support me: http://patreon.com/komzpa
>> Ahsan Hadi
> Ahsan Hadi
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20181206/ddeb9b09/attachment.html>
