[postgis-users] Status and plans regarding circular arcs support?
Paul Ramsey
pramsey at cleverelephant.ca
Tue Mar 13 06:59:29 PDT 2018
Hi Andrea,
In terms of "native" support for arcs, I believe the answer is "area,
length, distance, indexes and supportive output formats", full stop.
Everything else that accepts them does linearization.
In terms of future improvements, I know of no ongoing work,
particularly in the realm of things like constructive geometry or full
predicate support. Unfortunately it's always been a somewhat narrow
niche.
ATB,
P
On Mon, Mar 12, 2018 at 8:24 AM, Andrea Aime
<andrea.aime at geo-solutions.it> wrote:
> Hi,
> is there any document outlining the current status of arc support in
> PostGIS?
> In particular, a list of functions that can those that work off the native
> curves, and those that linear-ization instead (eventually, those that do
> not work at all against curvilinear geometries)?
> Maybe (and I might be dreaming here :-) ) with some indication of whether
> they will be improvements in that regard?
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
> for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
