[postgis-users] Postgresql 14 bug?: "variable not found in subplan target list"
Marco Boeringa
marco at boeringa.demon.nl
Sun Feb 13 13:31:56 PST 2022
Hi Imre,
Thanks.
However, since I use the VM with PostgreSQL for development exclusively,
and am not to bothered re-importing OpenStreetMap data, I actually
decided to first delete all contents from the databases I use for
testing, as this leads to near instantaneous upgrade, instead of needing
to wait for an extended amount of time for the upgrade to finish.
I then re-imported the data, so I am sure the data and indexes are
"fresh". I even went as far as dropping one the databases that showed
the issue, but was easily able to reproduce the issue with my current
workflow. Unfortunately, that is a whole bunch of Python code generating
SQL, and isn't easily compacted into a simple test case. So it is a bit
of digging around at first.
That said, your reference to a possible issue with the indexes, is a
possible lead to explore more.
I run PostgreSQL 14.2 by the way.
Marco
Op 13-2-2022 om 20:46 schreef Imre Samu:
> > after upgrading to PostgreSQL 14?
> > ... If I 'VACUUM (FULL)' the dataset, I get back the record count
> without issues.
> > ... Thoughts?
> imho:
> - Maybe the 'VACUUM (FULL)' is rebuilding your indexes - and solving
> some corrupted index problem?
> - As I see in 14.2 release notes: "reindexing is recommended"
> https://www.postgresql.org/docs/release/14.2/
> /"However, some bugs have been found that may have resulted in
> corrupted indexes, as explained in the first two changelog
> entries. If any of those cases apply to you, *it's recommended to
> reindex possibly-affected indexes after updating.*"/
> in 14.1 - this is also recommended:
> https://www.postgresql.org/docs/14/release-14-1.html
> / " it's recommended to reindex possibly-affected indexes
> after updating." /
> I don't know your upgrade process, but in this case, I will re-run the
> "reindexdb" utility
> ( https://www.postgresql.org/docs/14/app-reindexdb.html )
> Regards,
> Imre
> Marco Boeringa <marco at boeringa.demon.nl> ezt írta (időpont: 2022.
> febr. 13., V, 18:35):
> Hi,
> Anyone else running into issues with their process flow after
> upgrading
> to PostgreSQL 14?
> After my failed attempt to update GEOS and PROJ, as I wrote about in
> recent posts, I restored my backup VM with plain vanilla
> PostgreSQL 13
> and PostGIS 3.2.0 from the official apt repository of PostgreSQL,
> which
> also includes GEOS 3.8.0 and PROJ 6.3.1.
> I then upgraded my cluster to PostgreSQL 14, without any other
> changes
> or upgrades.
> Now I am running into a weird issue and error I have never seen
> before
> in the past four years of working with PostgreSQL:
> - On a dataset that has undergone some basic processing in
> PostgreSQL /
> PostGIS, including things like 'ST_SimplifyVW', 'ST_Transform',
> somewhere along the processing chain I get a "variable not found in
> subplan target list" type error. This happens on a very basic SQL
> statement, just:
> "SELECT COUNT(*) FROM <TABLE>"
> - If I view the data in pgAdmin or DBeaver, I can open the table and
> view it spatially without issues. Running the same SQL COUNT
> statement
> against the dataset from these tools query interfaces, does give
> me the
> same error though as in my code.
> - If I 'VACUUM' the dataset, the error persists.
> - If I 'VACUUM (FULL)' the dataset, I get back the record count
> without
> issues.
> Thoughts?
> Marco
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220213/a06c4304/attachment.html>
