[PROJ] Big grid files
Even Rouault
even.rouault at spatialys.com
Mon May 19 07:39:04 PDT 2025
Le 19/05/2025 à 16:33, Jack Riley - NOAA Federal a écrit :
> I read in
> https://proj.org/en/stable/specifications/geodetictiffgrids.html#general-description that
> files hosted on the CDN support Signed/Unsigned Int 16 and Int 32.
> Might this be expanded to include Int 8, given its support in
> GDAL>=3.7.0:
> https://gdal.org/en/stable/development/rfc/rfc87_signed_int8.html
That could potentially, but I'd suspect that the usage of compression +
Predictor=2 on a scaled to Int8 file (actually I believe you'd rather
want UInt8 if using scaling) stored on 16 bit should lead to files that
are only slightly bigger than if actually stored on Int8/UInt8. To be
verified by experimentation on your datasets.
http://www.spatialys.com
More information about the PROJ
