[PROJ] Big grid files
Jack Riley - NOAA Federal
jack.riley at noaa.gov
Mon May 19 09:32:08 PDT 2025
> Are you asking:
> If I want to submit a file to be part of the dataset/CDN-contents, and
> it's in Int8, is that ok?
Yes
> That sounds like the total range of values across the entire grid is
> only 100 mm or so. Is that what you mean?
I believe the max data range for mm precision in offset and scaled float
values into Int8 is a bit over 500 mm. Opening the target precision up to
5 mm affords a data range of 2.5 meters into Int8: That's my target
precision, and most of my gridded transformation components are within that
range.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250519/bde3af63/attachment.htm>
More information about the PROJ
