[Qgis-community-team] Localized files for QGIS-Documentation not in github?
Eduardo Gonzalez
eg at gismood.com
Sun Jun 15 15:02:51 PDT 2014
Hi Richard,
sorry I was working on the master branch.
I tried the "paver html -l es" and "paver html -l nl" both run without
errors but the documentation is coming out English.
The po files are correctly fetched from transifex, I can see them in the
i18n folders and that they are recently downloaded, that part seems ok to
me.
Regards,
Eduardo
On Sun, Jun 15, 2014 at 10:09 PM, Richard Duivenvoorde <richard at duif.net>
wrote:
> On 15-06-14 13:03, Eduardo Gonzalez wrote:
> > Hello,
> > I just tested successfully the new paver to build the documentation in
> > Windows. Works smoothly!
> > I thought of testing to build a language version of the documentation
> > but the localization files seem not to be present in the github project.
> > How would it be possible to build the documentation in a localized
> language?
> Hi Eduardo,
> the master branch of documentation is NOT translated, hence you will
> find no .po files in i18n directory
> BUT if you switch to manual_en_v2.2 branch you will see that there are
> .po files in the i18n directory. We translate the stable branch only.
> I just fixed some errors and the pavement.py file so you will be able to
> use paver to build localised documentation.
> Please read the instructions in the readme.rst of the manual_en_v2.2
> branch:
> https://github.com/qgis/QGIS-Documentation/tree/manual_en_v2.2
> You will need to download the tx.exe (transifex-client for windows) and
> create a .transifexrc (credentials) file.
> Please try the instructions, and let me know if you encounter problems,
> or succeed.
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20140616/f471d7bc/attachment.html>
More information about the Qgis-community-team
