[Qgis-developer] printing issues
Steven Bell botsnlinux at gmail.com
Thu Aug 2 08:34:09 EDT 2007
>Just a thought - would it be possible at least to make the point
>symbols be rendered at much higher resolution than currently?
I don't think so, since the same rendering functions are used to get the
point symbols for the map canvas.
However, that gives me an idea for a workaround:  Set the symbol size to be
much larger, and in the print composer, set the symbol scale to be much
smaller.  I doesn't work perfectly, but it might help until we can implement
a better fix.
Steven
On 8/2/07, Maciej Sieczka <tutey at o2.pl> wrote:
> Maciej Sieczka wrote:
> > Steven Bell wrote:
> >> Unfortunately, I don't think we can fix this for 0.9.  It will
> >> require some significant changes to the symbology and rendering,
> >> which has the potential to break things.
> > Really too bad. This is quite an issue.
> symbols be rendered at much higher resolution than currently? That
> would improve the map look enough not to notice the issue and be able
> to produce proffesionaly looking hardcopies/PDFs. It would be a decent,
> highly appreciated workaround until a fix is possible.
> Maciek
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070802/f8cb281f/attachment.html
