[Qgis-developer] configuration lost when running 2.0
Andrea Peri
aperi2007 at gmail.com
Wed Jun 12 09:50:48 PDT 2013
I give my fresh experience. :)
I'm running with both qgis (1.8 and 1.9 dev).
I need use both because I have an important project created from a
group of workers.
On qgis 1.8
Now I need to apply it on a qgis 1.9
But because the importing on qgis 1.9 has lost me
surely transparency and perhaps something on label setting.
I need constantly to move from qgis 1.8 and 1.9 to manually reset
every single layer.
My experience is that is absolutely need to use both in the same machine.
In the first period of transiction.
Almost for who has important qgis 1.8 project that don't want lost.
Regards,
Andrea.
>on Wed, Jun 12, 2013 at 11:57:28PM +1000, Nathan Woodrow wrote:
>>* That doesn't change the issue. The settings will still be moved and reset a*>>* fresh using --configpath.*>
>Yes, but it won't be the default.
>>* You would be surprised how many want to run bn*>
>I surely want to run 1.8 if 2.0 doesn't know about my connections :)
>My point here is what should the default be ?
>The current default is that upgrading from 1.8 to 2.0 creates a fresh
>configuration, loosing the old one (plugins included).
>I find this pretty annoying, as a user.
>If I understand correctly, the risk with using the same configuration
>with both 1.8 and 2.0 is that configuration changes I make while running
>with 1.8 would be immediately visible when running 2.0, and vice-versa.
>Sounds like a feature to me, not like a problem. So, what's the problem
>with that, exactly ?
>--strk;
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130612/a3f10448/attachment-0001.html>
