[Qgis-developer] QGIS API Distance, Azimuth/Bearing - API Documentation
C Hamilton
adenaculture at gmail.com
Fri Apr 21 05:49:12 PDT 2017
Thanks for your input. I will do some research on the GNU vs MIT license as
well as prepare a QGIS development environment and then see where I can go
from there.
All the best!!!
On Tue, Apr 18, 2017 at 11:37 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi
> On Thu, Apr 13, 2017 at 11:56 PM, C Hamilton <adenaculture at gmail.com>
> wrote:
> > Here are my questions.
> > 1. Sorry for my lack of knowledge here. I have gotten into the plugin
> > development and I have been thinking that I could possibly contribute to
> the
> > actual QGIS code, but I am not sure what you want done when you say to
> do a
> > "pull request on the topic".
> I meant to basically:
> 1. clone the QGIS source code repository from https://github.com/qgis/QGIS
> 2. build QGIS yourself - see https://github.com/qgis/QGIS/
> blob/master/INSTALL
> 3. create a branch and implement your changes in the branch
> 4. create a pull request in QGIS repository on GitHub
> > 2. geographiclib already has done the work for the more accurate geodesic
> > algorithms. They use the MIT/X11 license. Is that compatible with the
> QGIS
> > GNU2 license? It would certainly be easiest to use that code rather than
> > trying to reinvent it.
> It is possible that they are compatible, but I don't know - better to
> research that first...
> > 3. What is the best way to learn the steps necessary to contribute to the
> > core QGIS project?
> I think my reply above partially answers this question. Have a look also
> here:
> https://www.qgis.org/en/site/getinvolved/development/
> qgisdevelopersguide/index.html
> If you have further questions on how to get started, feel free to ask
> here on qgis-dev list.
> Regards
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170421/631f32ff/attachment.html>
