[QGIS-Developer] QGIS server vs LTR
Andreas Neumann
a.neumann at carto.net
Wed Aug 2 06:37:00 PDT 2017
I personally don't have any issues with QGIS server 2.18. I use it in
production.
I had a bug fixed with layer rendering order if one would call by a
group layer (esp. the root layer) without specifiying all leaf layers -
but it is fixed since a few weeks.
Other than that I don't have any issues - but I may not use all of the
features (like the legend stuff).
Andreas
On 02.08.2017 15:15, Paolo Cavallini wrote:
> Thanks Giovanni. However:
> Il 02/08/2017 15:06, Giovanni Manghi ha scritto:
>> As far as I have seen there are two major problems, one actually
>> caused by a change in QGIS Desktop layout composer, see:
>> https://lists.osgeo.org/pipermail/qgis-developer/2017-July/049400.html
>> So at is now QGIS Server 2.18.11 is basically broken for use within a
>> webgis application (no getprints if the layout has a label/text box),
>> also for me the problem with the legend is a blocker to its adoption.
> in my test print works even when text boxes are there, e.g.
> https://lizmap.faunalia.eu/index.php/view/map/?repository=faunalia&project=conca
> I think now that 2.18 is LTR we should either fix these issues or warn
> users to stick to 2.14 for a server.
> all the best.
