[QGIS-Developer] QGIS server vs LTR
René-Luc Dhont rldhont at gmail.com
Sun Aug 6 05:42:42 PDT 2017
Hi Devs,
To enhance QGIS Server 2.18, I have tested to add some test and I have
some trouble with Highlight layers.
Does some one have using this feature ?
René-Luc
Le 02/08/2017 à 15:37, Andreas Neumann a écrit :
> I personally don't have any issues with QGIS server 2.18. I use it in
> production.
> I had a bug fixed with layer rendering order if one would call by a
> group layer (esp. the root layer) without specifiying all leaf layers
> - but it is fixed since a few weeks.
> Other than that I don't have any issues - but I may not use all of the
> features (like the legend stuff).
> Andreas
> On 02.08.2017 15:15, Paolo Cavallini wrote:
>> Thanks Giovanni. However:
>> Il 02/08/2017 15:06, Giovanni Manghi ha scritto:
>>> As far as I have seen there are two major problems, one actually
>>> caused by a change in QGIS Desktop layout composer, see:
>>> https://lists.osgeo.org/pipermail/qgis-developer/2017-July/049400.html
>>> So at is now QGIS Server 2.18.11 is basically broken for use within a
>>> webgis application (no getprints if the layout has a label/text box),
>>> also for me the problem with the legend is a blocker to its adoption.
>> in my test print works even when text boxes are there, e.g.
>> https://lizmap.faunalia.eu/index.php/view/map/?repository=faunalia&project=conca
>> I think now that 2.18 is LTR we should either fix these issues or warn
>> users to stick to 2.14 for a server.
>> all the best.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
