[Qgis-developer] Proposal - Change mIconProjectionEnable/Disable Icons
Nyall Dawson nyall.dawson at gmail.com
Sun Jan 15 16:29:07 PST 2017
On 16 January 2017 at 09:56, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Proposal: for consistency, change the current mIconProjectionEnable and
> mIconProjectionDisable Icons. These are the Icons next to the EPSG code
> Rationale: While converting those icons from PNG to SVG, I could not
> understand what they were, or try to represent. Besides, these buttons open
> the CRS tab in project properties, which uses another Icon (CRS.svg). So,
> for consistency and user's recognition, it would be better to use always the
> same icon when we are referring to select a CRS.
> My idea is to use the CRS.svg icon as a base to create a version for
> enable/disable icons that look good at 16x16 pixels.
> http://imgur.com/O7hKsmK
> I would also replace the Icon in the capture coordinates plugin, which is
> the same.
While we're on this - what about changing the logic so that instead of
showing "(OTF)" when reprojection is enabled to instead showing "(OTF
off)" when it's DISABLED. I think reprojection on normal for 99% of
users and it's more important that we instead alert users when it's
NOT switched on (as the map could be misleading).
Nyall
> Alexandre Neto
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
