[QGIS-Developer] [Processing] Dissolve with unique field cause segmentation fault
Giovanni Manghi giovanni.manghi at gmail.com
Wed Jul 5 13:02:05 PDT 2017
Hi Matteo,
> Hi devs,
> don't hate me if I'm bombing the list, but I'm going through the
> Processing algorithm making tests as deep as I can.
> The Dissolve algorithms work super fine except when an unique field is
> chosen for the dissolving. In this case I have a segmentation fault and
> QGIS crashes.
> Tried with different dataset and it happens every time.
> I don't have any log information, just segmentation fault
if this issues you are finding (by the way thanks a lot for the
testing) do affect only master, then please file a regression ticket
straight away on the bug tracker (affected version "master" of
course). With the Processing overhaul is kind of expected to have a
lot of things to be fixed, better not lose track of any of them.
cheers
-- G --
More information about the QGIS-Developer mailing list
