[QGIS-Developer] Incremental drawing possible?
    Martin Dobias
    wonder.sk at gmail.com
    Tue Jul 11 01:48:40 PDT 2017
Hi Andreas
On Tue, Jul 11, 2017 at 9:38 AM, Neumann, Andreas <a.neumann at carto.net> wrote:
> Hi Martin,
> I noticed that loading and redraw only happens when the mouse button is
> released after the panning operation. While I understand the reasoning for
> this (definitely on the safe side and no unnecessary redraws), I wonder, if
> for WMTS, loading and display could already happen while panning and the
> mouse button isn't yet released, e.g. triggered whenever a certain threshold
> of panning distance (e.g. in percent of the last extent) was surpassed.
> This would be even nicer than the current behaviour. Or are there technical
> reasons, not to do that? Google maps works like this. It redraws while
> panning.
Good news - there are no technical reasons that would prohibit us from
such improvement. Background rendering could start earlier, we just
need to add logic for such behavior. There is already a pending pull
request from Nyall to render adjacent parts of map canvas once
rendering of the visible area has finished - that may already be a
sufficient solution - I have not had time to play with it yet though.
Maybe these two approaches (render on map dragging, render outside of
current view) can be combined somehow for the best UX while keeping
overhead of extra rendering low.
We could even think about moving more towards tile-based approach to
rendering of map canvas, with the advantage of being able to cache map
tiles from previous canvas redraws for the same scale. This would
allow instant appearance of areas previously rendered with lower CPU
use at the expense of consuming more memory and having more
complicated logic for labeling.
Regards
Martin
