[QGIS-Developer] QGIS/OGR: FeatureIds reassigned on write to data provider?
Sandro Mani
manisandro at gmail.com
Wed Jul 12 04:00:03 PDT 2017
On 12.07.2017 11:41, Luigi Pirelli wrote:
> why not add the feature to a more detailed notification of what is
> wrong during commitChanges? Like point out a more detailed report of
> the failing feature/attribute/geometry? it would just a new signal and
> EditBuffer cache.
Uhm but that would still mean the changeset cannot be committed.
And as a side-note, the edit-buffer inbetween brings a number of
challenges like:
- The user manually exiting the edit mode while the plugin is working
- The user changing something outside the control of the plugin. The
plugin is fairly complex in that it updates all other errors based on
the outcome of a fix - say, if you delete a duplicate node, it may have
an effect of the vertex id used to describe a "minimal angle" error.
Updating the errors works well as long as the plugin knows exactly what
is going on, but if the user starts fiddling inbetween, it gets a real
proper nightmare to track and handle all changes. Indeed, currently the
plugin sets the layers to non-editable while it is working so that,
short of removing the layer from the project, there is not much the user
can do to interfere with the logic of the plugin.
Sandro
