[QGIS-Developer] Let (C)Make run sipify?
Denis Rouzaud denis.rouzaud at gmail.com
Thu Jun 15 04:39:27 PDT 2017
Le jeu. 15 juin 2017 à 13:11, Sandro Santilli <strk at kbt.io> a écrit :
> On Thu, Jun 15, 2017 at 09:00:21AM +0000, Denis Rouzaud wrote:
> > Le jeu. 15 juin 2017 à 10:13, Sandro Santilli <strk at kbt.io> a écrit :
> > > So rather than a compile error, you should get an automated build of
> > > the missing files.
> > > Likewise, generated files should not be in the GIT repository (as they
> > > are not things you want to edit manually).
> > > Is the above achievable ?
> > Yes this is totally achievable. That's the option 4, slightly modified.
> So my vote goes to option 4 - inlined for easy of access:
>     4) cmake for both without sip in source
>         - similar to above
>         - is sipify stable enough? not sure.
> > I'm just not very keen on removing sip files from source at the moment,
> at
> > least until all files are sipified, but it should not be too long until
> > then.
> About the "is sipify stable enough?" question, you might have noticed
> my bug report: https://issues.qgis.org/issues/16710
> It could maybe  be useful to have a component for issues related to
> sipification, what do you think ?
I just created the categories in the tracker (python bindings / sipify).
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170615/2771bb7c/attachment.html>
More information about the QGIS-Developer mailing list
