[Qgis-developer] PyQgsServerTest :: test_wms_getprint_srs disabled
Paul Blottiere
paul.blottiere at oslandia.com
Tue Mar 7 00:12:56 PST 2017
> It sounds strange to me that it was never observed in production, but
I did not search the hub for an existing ticket, it might have been
reported.
The test seems to fail in very specific conditions (that I have not yet
found). As Mathias suggested, I made a loop on the test. And even with
1000 iterations, it's still not failing whatever the branch (master or
2.14)... Maybe it has never been observed.
Paul
On 03/07/2017 08:53 AM, Alessandro Pasotti wrote:
> On Tue, Mar 7, 2017 at 8:48 AM, Paul Blottiere
> <paul.blottiere at oslandia.com <mailto:paul.blottiere at oslandia.com>> wrote:
> Alessandro,
> > do you have clue if the multi-threading rendering could be the root cause of this issue?
> The test is failing on travis for 2.14 too. However, PR about the
> replacement of the QgsMapRenderer and the parallel rendering
> activation are not backported in 2.14. So, as it happens both on
> master and 2.14, it seems to be independent from the rendering step.
> Only unit tests on the getprint service has been backported and
> before that, there was none. So I think that the failing test is
> just underlying an old issue which was there even before we
> started to refactor the server.
> What do you think?
> I'm afraid you are right ...
> It will be difficult to spot it out, by the way I think that the test
> did a good work to discover this issue.
> reported.
> Paul
> On 03/07/2017 08:16 AM, Alessandro Pasotti wrote:
>> On Mon, Mar 6, 2017 at 5:30 PM, Paul Blottiere
>> <blottiere.paul at gmail.com <mailto:blottiere.paul at gmail.com>> wrote:
>> Hi Alessandro,
>>>> can you please have a look?
>>>> I'm afraid this failure is not a problem in the test itself
>>>> but a symptom of more serious issue: the map is completely
>>>> missing from the generated print.
>>> FYI, the same test also fails on 2.14 as discussed on the
>>> following commit:
>> I took a look but I cannot reproduce the failing test
>> test_wms_getprint_srs.
>> Actually, I have tested it within the next environment
>> without issues:
>> - master on Debian
>> - release-2_14 on Ubuntu.
>> Can anyone confirm?
>> Paul
>> Paul,
>> Thanks for looking into this, I'll do some local testing shortly,
>> A s a side note, I would recommend to refactor the server test
>> and split it in smaller dedicated tests for the different services.
>> Alessandro Pasotti
>> w3: www.itopen.it <http://www.itopen.it>
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170307/5639c89a/attachment-0001.html>
