[Qgis-developer] PyQgsServerTest :: test_wms_getprint_srs disabled
Alessandro Pasotti apasotti at gmail.com
Wed Mar 8 02:28:03 PST 2017
On Tue, Mar 7, 2017 at 9:12 AM, Paul Blottiere <paul.blottiere at oslandia.com>
wrote:
> > It sounds strange to me that it was never observed in production, but I
> did not search the hub for an existing ticket, it might have been reported.
> The test seems to fail in very specific conditions (that I have not yet
> found). As Mathias suggested, I made a loop on the test. And even with 1000
> iterations, it's still not failing whatever the branch (master or 2.14)...
> Maybe it has never been observed.
> Paul
I tried to reproduce the issue locally without success.
I suggest for now to either split the printing tests into a separate file
or better (if there is single test failing) just decorate the test as
allowed to fail so that the whole suite does not fail.
When done, we can re-enable the server test in travis.
> On 03/07/2017 08:53 AM, Alessandro Pasotti wrote:
> On Tue, Mar 7, 2017 at 8:48 AM, Paul Blottiere <
> paul.blottiere at oslandia.com> wrote:
>> Alessandro,
>> > do you have clue if the multi-threading rendering could be the root
>> cause of this issue?
>> The test is failing on travis for 2.14 too. However, PR about the
>> replacement of the QgsMapRenderer and the parallel rendering activation are
>> not backported in 2.14. So, as it happens both on master and 2.14, it seems
>> to be independent from the rendering step.
>> Only unit tests on the getprint service has been backported and before
>> that, there was none. So I think that the failing test is just underlying
>> an old issue which was there even before we started to refactor the server.
>> What do you think?
> I'm afraid you are right ...
> It will be difficult to spot it out, by the way I think that the test did
> a good work to discover this issue.
>> Paul
>> On 03/07/2017 08:16 AM, Alessandro Pasotti wrote:
>> On Mon, Mar 6, 2017 at 5:30 PM, Paul Blottiere <blottiere.paul at gmail.com>
>> wrote:
>>> Hi Alessandro,
>>> can you please have a look?
>>> I'm afraid this failure is not a problem in the test itself but a
>>> symptom of more serious issue: the map is completely missing from the
>>> generated print.
>>> FYI, the same test also fails on 2.14 as discussed on the following
>>> commit:
>>> I took a look but I cannot reproduce the failing test
>>> test_wms_getprint_srs.
>>> Actually, I have tested it within the next environment without issues:
>>> - master on Debian
>>> - release-2_14 on Ubuntu.
>>> Can anyone confirm?
>>> Paul
>> Paul,
>> Thanks for looking into this, I'll do some local testing shortly, do you
>> have clue if the multi-threading rendering could be the root cause of this
>> issue?
>> A s a side note, I would recommend to refactor the server test and split
>> it in smaller dedicated tests for the different services.
>> Alessandro Pasotti
>> w3:   www.itopen.it
>> Qgis-developer mailing listQgis-developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti w3:   www.itopen.it
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170308/eae945a0/attachment.html>
