[QGIS-Developer] Release 2.18.8 on Ubuntu 16.04 dies loading delimited text file
DelazJ delazj at gmail.com
Mon May 22 16:49:59 PDT 2017
should be fixed now https://issues.qgis.org/issues/16600#change-79959
2017-05-23 1:05 GMT+02:00 Chris Crook <ccrook at linz.govt.nz>:
> Hi
> Last night I installed version 2.18.8 onto ubuntu 16.04 (via automatic
> upgrade).  This seems to have killed the delimited text provider.
> Symptoms are:
>     Open delimited text dialog
>     Select simple .csv file with lat and lon fields
>     Click OK
>      ... QGIS dies immediately
> Normal behaviour would be to open CRS selection dialog and then display
> the layer.
> Note that existing projects with delimited text layers load properly and
> display the layer, so this is an issue with creating the layer, not
> displaying it.
> I have tried removing and reinstalling QGIS and all its dependencies and
> the issue is persisting.
> I'm installing from the http://qgis.org/debian repository
> This was working without issue on 2.18.7.
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170523/8c9ccbad/attachment.html>
More information about the QGIS-Developer mailing list
